Help Figuring out my Harley...
Old May 4, 2009 | 07:42 PM
CcHARLEYcC's Avatar
Hey guys....new to the forum...new to the harley family. Been loving these trucks since I graduated high school in 2000....now 9 years later and i decided to buy me a 2003 two tone. Found it in Kansas City (I'm in MIAMI!!!)
with very low miles, full factory warranty and extended warranty thru FORD....so why not. Now comes the part that i'm kind of egh about. This truck had some performance mods done to it before....majority been removed but I know it must have some parts still on because im boosting 13-15psi on the charger and 411rwhp on the dyno. I already bought the Diablo Tuner and had it tuned at a shop since the dealership flashed the ECU before me buying it. My problem is this, I don't know what pulley sizes the previous owner has installed, i don't know if he upgraded the fuel pump to a 255walhbro, what thermostator anything else.....any shop around my area wants tocharge $150+ just to look at parts and figure it out, i think that's ridiculous since honestly I just want to know what Pulley's I have installed. So the question.....HOW DO I FIGURE OUT WHAT PULLEY SIZE I HAVE INSTALLED?
Thanks in advance for your help
Old May 4, 2009 | 11:43 PM
Veteran: Army
#1 welcome
#2 break out the tape measure / is the crank pulley caged?
#3 it's safe to guess they PO left the stock fuel pumps and the stock 180* thermostat i there
#4 sounds like it's got a 6# lower and a decent tune
#5 does it have long tube headers?
Old May 5, 2009 | 11:37 AM
CcHARLEYcC's Avatar
i see the upper pulley, not caged. Honestly looks like the factory upper pulley. Headers look stock, previous owner left cherry popper pipes but not a full exhaust system.
Old May 5, 2009 | 11:40 AM
Welcome to the site! Sounds as if you got yourself a great truck.
Oh, and we need pics!
Old May 5, 2009 | 11:41 AM
CcHARLEYcC's Avatar
get some decent pics up minute i have a chance
Old May 5, 2009 | 11:54 AM
Veteran: Army
what size is the upper pulley??
the crank pulley would be the caged one if it was a stock crank pulley
Old May 5, 2009 | 11:59 AM
OKI's Avatar
OKI
Welcome to the site.
Like terajarame said...get a tape measure and measure across the "LOWER" pulley and tell us how many inches it is and we will tell you what size lower pulley you have.
Without knowing what, if any internals of that engine have been upgraded, as your crank is the only thing that is forged from the factory...I would not push anymore than 12lbs of boost on a stock block as you may join the vented block club sooner than later. Also, be careful at outside temps of 60 degree's or lower...NO 2 GEAR KICKDOWNS!!!!
Pictures of the engine bay could help also.
As for what thermostat you have...you have to get the water pump off to get to the thermostat and that is a pain in the ARS, in my opinion...best guess is your probably running the stock thermostat still.
The fuel pumps your gonna have to drop the tank or take your bed off to get to those to see if they are stock or not.
Nice choice on getting the 03 two tone also!!!!
Any other questions you may have there are some other good sites for advice you may want to check out.
www.nhtoc.com
www.nloc.net
www.lightningrodder.com
Old May 5, 2009 | 01:18 PM
CcHARLEYcC's Avatar
ok rookie question....is the lower pulley the big a$$ one that can be seen from under the car?
Old May 5, 2009 | 01:23 PM
OKI's Avatar
OKI
Yes...at the bottom, it will be the biggest you got. Depending upon what fan set up you have...if memory serves me correct...the stock fan is directly across from it, as I believe that is how the fan turns when the truck is on.
I upgraded my fan to a Dual Speed, E-Fan
Old May 5, 2009 | 01:38 PM
CcHARLEYcC's Avatar
check that out minute i get out of the office today....thanks alot for your help guys. Good thing i found this nice forum because I couldn't find a decent place to read about mods
stock fan is connected to the water pump in the center of the engine accessories
Old May 5, 2009 | 01:40 PM
OKI's Avatar
OKI
That's right...thanks. So glad that is gone now as that was a pain the A$$ to get off
Old May 5, 2009 | 01:42 PM
when you have the right tools its very easy :o
I agree tho Electric Fans are a great upgrade on our trucks
Old May 5, 2009 | 01:45 PM
OKI's Avatar
OKI
Here is a pic to help you out....
