Not enough power! (electrical problem)
Hello everyone i have an 03 harley davidson f-150 and i am having what appears to be a shortage of power. I installed an xm radio, fm modulator, a small 6" lcd screen, and an old desktop computer which is running off of a power interverter. All that seems to be dropping the voltage to below acceptable levels because the computer starts having problems running and the lcd screen gets interference. I was wondering if anyone knew of a way to overcome this? Would a higher quality battery fix it? Or do i have to run 2 batteries, or even a better alternator? Thanks in advance for any help!
my guess is you probably want both. Get a optima yellow top and a high output alternator.
Are you sure the output level of the inverter can handle a desktop? My desktop has a 400 watt power supply, which i know it doesnt use all of, but its at least in the 200 zone.
Thank you for the reply grinomyte, i am using an old 700mhz system with a 250watt psu, but even then its probably pulling about 150 watts. I know its not a problem with the inverter becuase i plugged the inverter into a desktop DC power supply to test it and the computer ran perfectly. So that means its a problem with the truck. When you said i need both, did you mean i need a dual battery setup and a new alternator? Also, do you think i would be ok if i used a mini itx system instead? Something like that would probably only pull around 60 watts i would guess.
i don't think you'll need dual battery unless your running the machine with the truck off alot. I think just a yellow top and a high output alternator would do it.
Why not buy a laptop and use that instead? Much less power draw.
I think the solution is to just run a direct hookup to the battery itself. Right now i am using an inverter through a cigarette lighter and it isn't working.. I just don't know how i can get a cable from inside the truck to the battery without drilling holes.
is the power inverter big enough to power a PC? don't be fooled by cheap ones! get one thats bigger than what you need.
did you think that the interference on your LCD screen could be caused by the inverter and/or PC?
the wiring on the cig lighter may not be able to handle the current needed for the inverter..
I would say the inverter is your problem, when inverters are pushed too hard they will generate lots of noise which is being picked up by your screen.
