Factory Tech Valve Body Question
Old Jan 31, 2003 | 06:27 PM
Db682's Avatar
Question Factory Tech Valve Body Question
I was just wondering if anybody else that has the Factory Tech Valve Body has Noticed that when your ***** to the wall with the gas pedal that as the tranny shifts there is a loud purge sound from under the truck. Ive had this thing for about a year now and everytime Im hauling *** I hear that sound and wonder if its normal.
Old Jan 31, 2003 | 10:52 PM
ken800's Avatar
purge sound?
Could it be a screech from the accessory belt slipping on hard shifts? Mine does that but I haven't had the time to swap the belt.
Otherwise, I don't know. Maybe you could describe the sound a little better and Gregg can give you an idea...
Ken
Old Feb 1, 2003 | 04:56 PM
Db682's Avatar
I never thought of that
Thanks Ken, Ill have to check a little better and find out if it is the acces. belt. IThat thought never even passed my mind. But it could be it. It almost does sound like a belt slipping. Ive never changed one out before. Is it much work and is there any way to check the belt before I do?
Old Feb 1, 2003 | 05:16 PM
slingshot's Avatar
I know exactly what sound you are talking about! Mine only does it if you romp on it and let off right before the shift... like a 'squirt', kinda screetch... hard to describe. Doesn't do it on full-throttle upshifts (those freakin' rip!) or regular part throttle shifts. But I have noticed it...
Old Feb 1, 2003 | 07:55 PM
speeder's Avatar
Your probably just hearing the belt screetch when your truck shifts. my truck does the same thing.
Larry.
Old Feb 1, 2003 | 08:33 PM
HD4mula's Avatar
I haven't heard anything on mine. I'll listen more carefuly from now on.
