valve knock ??
Old Dec 28, 2002 | 05:14 PM
grayhd2's Avatar
valve knock ??
just started noticing what sounds like valves knocking/rattling when I first start the engine...... cold. Never noticed before...... is this normal ?? Just has 3000 miles on it !!!
Old Dec 28, 2002 | 06:09 PM
ken800's Avatar
do a search in the L forum and you will find a lot of people complaining about it on startup in the colder months...
I put mobil one 5w30 in my truck and it eliminated the marbles in a can sound if that is what you are referring to.
Ken
Old Dec 28, 2002 | 06:29 PM
JCZ's Avatar
JCZ
What area are you in? How cold is it? I've noticed a little noise at start up in the early a.m. (high 30's to low 40's) but it goes away after just a couple minutes. I attribute it to the oil draining down in the cylinders when I park, then the fact that it's cold in the morning takes a couple minutes to pump up.
Next oil change this kid is switching to synthetic oil.
Old Dec 29, 2002 | 10:45 AM
grayhd2's Avatar
marbles in the can is exactly what it sounds like..... just for a few minutes. I think it's time for some Mobil 1...... thanks guys !!
Old Dec 29, 2002 | 03:39 PM
FXDX's Avatar
The synthetic might help some but these OHC engines are noisy to begin with. Mine has rattled since new! Somewhat more pronounced in colder temps especially upon initial start-up. I have ran Mobil-1, 5W-30 since the first oil change at 1000 miles. Minimal difference in noise!
Old Dec 29, 2002 | 10:36 PM
bow-tieKILLR's Avatar
Piston slap, my 99L does it when it gets cold. Try synthetic oil.
