Remote Keyless Entry
You have the three button fob?
Turn the ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. All doors will lock then unlock to confirm programming mode. Press any button on the first remote transmitter. Door locks will cycle to confirm programming. Press any button on the second transmitter (up to 4 transmitters possiable). Turn ignition to OFF. Locks will cycle again to indicate end of programming mode.
Sorry it took so long, I had to get the info from work and to remember it
Hope it helps
.Hope it helps
