Wheels/rim fitting
Old Aug 17, 2017 | 05:28 PM
BAMAISBEAST's Avatar
Wheels/rim fitting
I have a 1989 f150 4x4 long wheel base with the inline6 4 speed Manuel trans, I have stock 15 inch rims I want to go up to 16's or 17's because I would like to put 33 12.50's on my truck. The back end has 2 inch blocks so it looks jacked up I didn't put there... Thing is if I got either size rims(stock) would the 33 12.50's fit on the stock rims? I found a set of stock 16 inch rims on a 2000 f150 2 wheel drive will they fit and would I have to buy a lvling kit for the front? And will it scrub if I don't?
Old Aug 18, 2017 | 05:50 AM
05RedFX4's Avatar
The 2000 wheels have a 5 x 135mm bolt pattern, and I believe the 89 wheels used a 5 x 127mm or 5" pattern. so I don't think they will physically bolt up.
Old Aug 18, 2017 | 10:33 AM
BROTHERDAVE's Avatar
25 Year Member
i doubt those rims will fit your truck
the 89 straight six is so underpowered, the bigger tires are going to kill your performance.
I would go to discount tire and pick out a inexpesive aftermarket rim.
american racing ar767 $88.00 each in a 16 x 8
or american racing ar172
i think both would look good on the truck and give it a fresh look.
i would go with a 265/75/16 tire. 31.5 tall about 10.4 wide
