interchangable
Old Oct 7, 2016 | 06:03 PM
dennisallen's Avatar
interchangable
can i take the 4.6 out of my 97 grand marquis and put it in my 1999 ford f 150 4.6l
Old Oct 9, 2016 | 11:14 AM
05RedFX4's Avatar
You might have some oil pan issues, and intake issues. But if you do, just swap on the F150 specific parts that you need. Years ago, I did a similar swap into an 87 t-bird and put in a 302 destined for an F150, I had to reuse the t-bird oil pan and intake manifold put afterwards it looked and ran factory.
Old Oct 15, 2016 | 07:46 PM
01 gt f150's Avatar
The heads are different. P.I heads vs non P.I. and about 20 hp
Old Oct 15, 2016 | 09:04 PM
No, they are both non-PI. The 4.6 didn't go PI till 2001 model year.
Old Oct 16, 2016 | 05:10 PM
01 gt f150's Avatar
my bad, I thought it was 99. In that case if I was him I would change it over to P.I.'s and the all aluminum truck intake and ditch the composite. A friend of mine had problems with the crossover and we found the aluminum one. 5 years later no problems. We installed E-Fans and a mustang temp sender in the crossover and it works flawlessly. Same set up as mine.
