P7 CPU Chip
Old Jan 14, 2014 | 04:46 PM
Takeda's Avatar
P7 CPU Chip
While working for IBM, I developed, and taught a semiconductor (microelectronics) course. One of my "show and tells" was a P7 CPU chip (wafer, and modules). The P7 was developed by IBM in 2009, using a 45nm (nanometer) technology. 45nm is the minimum feature size (poly width) for the chip design. The P7 successor is the P8 CPU.
Here are some photos, that I thought would be of interest. The DOF is extremely shallow in some of the photos, even at f/22.
1 300mm silicon wafer. Red rectangle is one of many P7 CPU chips on the wafer.
2 Closer image of P7 CPU chip.
3 P7 CPU chip size comparison to penny.
4 Magnified edge of P7 CPU chip.
5 Magnified edge of P7 CPU chip.
6 Eye of needle used for size reference. Spherical shapes are solder ***** used for I/O, power, and ground connections to chip.
7 Black rectangle is backside of “diced” chip attached to ceramic substrate. Chip solder ***** are reflowed to attach chip to ceramic substrate.
8 Edge of ceramic substrate.
9 Bottom of ceramic substrate. Gold pads are for chip connections to socket/card.
10 Top of completed module.
11 Edge of completed module.
12 Bottom of completed module.
Old Jan 14, 2014 | 05:05 PM
JackandJanet's Avatar
It's completely amazing to me that it all works.
Nice pictures, as always.
Edit: This may be a totally stupid/dumb question, but do you or anyone know why rectangular chips are produced on round wafers?
- Jack
Old Jan 14, 2014 | 05:17 PM
Takeda's Avatar
- Jack
Good question!
The wafers are sliced from a cylinder, which is round by the way it is fabricated. Chips are either square or rectangular, because their image is "stepped" across the wafer.
Old Jan 15, 2014 | 09:19 AM
Takeda's Avatar
Check out this link for P7 CPU specs: http://www.7-cpu.com/cpu/Power7.html
Old Jan 15, 2014 | 05:56 PM
Originally Posted by Takeda
Good question!
I never thought to question the design of a chip. Using a rectangle or square shape maximizes surface area and, I suspect it works best with the shape of the internal circuitry.
And, I suppose a cylindrical wafer blank is easier to fabricate than a rectangular one. Still, I can't help but notice the wasted area around the perimeter, and it seems to me a rectangular wafer would be more efficient. But, I imagine the fab engineers have considered all this, rejecting my thoughts.
- Jack
Old Jan 15, 2014 | 06:13 PM
Takeda's Avatar
- Jack
Jack, the silicon "cylinder" is pulled from molten silicon, while spinning. This is why it is round, instead of square. And a round wafer is easier to handle through the different processes.
Old Jan 15, 2014 | 06:21 PM
Takeda's Avatar
Jack, here ya go, I found a video of the wafer making process:
Old Jan 16, 2014 | 12:31 PM
Thanks, Takeda. That clears things up very well. I suppose I could have found that myself if I had used my search finger, but like some others, I was just too lazy at the time.
It's still fascinating to me that a silicon chip can do so much, so reliably. I know that CPUs can fail, but they must be the last components to do so in normal use. Those tiny solder points are just amazing too.
I attempted to find information on the manufacturing failure rate of these components and didn't really succeed, possibly because the answer doesn't exist since chips may still be used if they are not "perfect" and actual yield rates may be confidential. However, I found this well-written article that's only 4.5 years old, so it should still be fairly relevant: http://www.geek.com/chips/from-sand-...s-made-832492/
Having taught digital processor/systems design for many years, I'm in awe of the physical design of modern ULSI circuits. What an amazing design/development process!
- Jack
Old Jan 16, 2014 | 11:25 PM
Takeda's Avatar
- Jack
You mention yield, and failure rate Jack. Two different things Jack. To yield is confidential, but typically, worst case failure rates are published. I'll see if I can find some information on this for you. Device infant mortality can be improved with burn-in processes, with a cost adder.
Old Dec 27, 2014 | 12:50 PM
Takeda's Avatar
A new photo using extension tubes. Eye of the needle for size comparison:
Old Dec 27, 2014 | 01:22 PM
Amazing, the uniformity of those tiny solder points!
- Jack
Old Dec 27, 2014 | 08:41 PM
Takeda's Avatar
- Jack
Thank you Jack.
Old Dec 28, 2014 | 12:07 PM
joe51's Avatar
- Jack
Adding the insulating, semi-conducting and conducting layers and "features" is the real work when fabricating ICs so it's not as much of a waste as you might think since no features are added to those edge pieces. Also the raw silicon edge pieces can be melted and reused to create new wafers.
Old Dec 28, 2014 | 12:11 PM
Takeda's Avatar
The newer semiconductor technologies uses S.O.I. (Silicon On Insulator) so the edge pieces cannot be melted down.
Old Dec 29, 2014 | 12:21 PM
joe51's Avatar
Interesting. Have not kept up with some of the newer processes since retiring. How do you grow that on a crystal boule? Or is it created by another process?
