Remote start problem, any guesses?
Old Nov 17, 2011 | 02:58 PM
Thad's Avatar
I have a problem with my remote start when the weather gets very cold. Actually it has happened once this season already. I start the truck [2010 f150, 5.4], 10 minutes later I get in, do up the seat belt and go. The truck does not recognize the seat belt being done up. The bell rings until I shut off the truck and restart with the key. After restart it is fine. I will have to leave it at the dealer when it gets colder but if I had an idea what the problem is it would help.
With the seat belt flashing on the dash and the bell going I wonder if the airbag or the belt tentioner would work.
Old Nov 17, 2011 | 07:16 PM
arrbilly's Avatar
until you get the problem fixed, simply hit the brake to shut it off when you get in the truck and restart it. PITA sure, but is a temporary fix...
regards
Old Nov 17, 2011 | 07:25 PM
arrbilly's Avatar
who installed it, you or a professional? If you had it done by a pro, take it back and get it looked after. The dealer won't help you as your problem is the result of after-market parts.
Are you putting on your seatbelt before or after you turn the ignition and hit the brake?
Old Nov 18, 2011 | 02:29 PM
05supercrew's Avatar
Is this a stock system or aftermarket?
Old Nov 18, 2011 | 03:09 PM
GB150's Avatar
Just disable the seatbelt reminder. The process of how to do it is in the owners manual.
Old Nov 18, 2011 | 07:31 PM
Thad's Avatar
Remote start was installed by Ford dealer as ordered by my factory order. Ford remote start. I would rather not restart every time it happens but until its fixed I guess I will have to. When it happens the truck is running from remote start, I put on the seat belt, put in the key, step on the brake, put it in gear and go.
Old Nov 18, 2011 | 08:18 PM
arrbilly's Avatar
so, try turning on the ignition, stepping on the brake, then put your seatbelt on...
regards
Old Nov 18, 2011 | 08:53 PM
Thad's Avatar
I'll try that.
