Wheel bearing?
Old Aug 24, 2011 | 01:36 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Wheel bearing?
On my way to dialysis this morning i hear a noise coming from the front of my Ford 500 humming noise which i think is a wheel bearing, how can i tell which one it is?. I turn the wheel to the left and the humming goes away?. I simply can't afford to replace them both at the moment so any help here would be great.
Old Aug 24, 2011 | 01:49 PM
If it goes away when you turn left, it is usually the left one. Turning right puts more pressure on the left one, and you should hear it better. Usually, if you jack it up and spin the wheel, you can hear/feel the roughness of the pitted bearing.
Old Aug 24, 2011 | 03:01 PM
Alex_4.2L's Avatar
Also if you jack it up and push/pull on the top of the wheel and bottom of the wheel there shouldn't be any play at all.
Old Aug 24, 2011 | 04:18 PM
It's AWD so i'll try the push pull and go from there. I just hope it lasts until the weekend...
Old Aug 24, 2011 | 04:22 PM
If you're just now noticing it, if it's a wheel bearing, should last awhile. I hope it's not something in the AWD.
Old Aug 24, 2011 | 04:53 PM
dirt bike dave's Avatar
I agree with Bluejay, a wheel bearing usually won't fail for a long time after it starts making noise/vibration.
FWIW, it might just be loose and need a bit of tightening (not too tight, though!). Don't know about the 4x4, but on a 2x4 it's pretty easy to pack in a little more grease and snug it up some. All that costs is a few pennies worth of grease and a new cotter pin.
Old Aug 24, 2011 | 05:05 PM
JackandJanet's Avatar
Bucky - a question, since I don't know: Does your car have CV joints? Your saying it's an AWD makes me think it might. If it does, it's possible one (or both) are failing. A CV joint will often make noise when turning one way and not the other. (I think turning away from the effected joint is what puts stress on it and causes the noise, but I could be wrong.)
Anyway, if it has CV joints, have a good look at the boots that cover them. They're easily torn, which lets in dirt, which damages the joint. If you see any cover damage, I'd bet that's where you'll find the problem.
- Jack
Old Aug 24, 2011 | 05:10 PM
- Jack
Excellent point. I never thought about CV joints. I don't know if AWD uses them or not. Probably do.
Old Aug 24, 2011 | 06:32 PM
All front drive mechanisms I'm aware of that aren't solid axle use CV joints.
Old Aug 24, 2011 | 09:50 PM
I'll check it out thanks everyone
