Bad experience w/Ford Truck Enthusiasts Forum
Old Aug 7, 2011 | 02:37 AM
MTM Ford's Avatar
Originally Posted by Gotts2BMe
I would like to throw my 2 cents out there on this. A lot members on here and else where will spend a lot of timing reading and searching but not a lot of posting. They don't comment on every post about oil viscosity, pics of lifts, rims, intakes, exhausts, etc. This stuff has been beat to death on this forum. They may come across dtc Pxxxx which almost all have been beat to death as well. Anyway something I would like the moderators to consider is implementing a 3 month or 10 post rule to the classified section. Whichever comes first.
You left out the "Ecoboost or 5.0?" threads
You are onto something though.
Old Nov 25, 2019 | 09:44 PM
Roger Rosecrans's Avatar
Angry Also banned from FTE.
I wondered if I was the only one banned after the first post. Guess not. I was having trouble finding a solution for slow turn signals on my 92 F-250. Finally tried the forum, and after wading though the good, bad, and garbage posts, I found one suggesting using an LED flasher instead of the OEM flasher given that it uses the actual voltage instead of heat in the line to break the circuit. I googled led flashers and found one that would be worth a try. It worked and I put in my first post after registering on the site. It included the part number, cost, source, and how well it fit, and worked along with my vehicle and details of my search. My post appeared for a few hours and then was removed along with a nasty gram from the moderator ( IB Tim) claiming I was the "spammer of the worst kind," and that I was banned " for ever." I pointed out to them that I used an F-250 header thread for the same vehicle as my guide for the post since it contained the exact same elements that I put in my post. That being the source, part number, name and cost. I still have not heard back from them. You try and do other readers a service to save them wasted time under their dash, and for your efforts you get a sarcastic email and are banned from the site by the moderator. I read the post rules and this was not spam imo.
Roger in Tucson
Old Dec 15, 2019 | 07:45 PM
Originally Posted by Roger Rosecrans
I wondered if I was the only one banned after the first post. Guess not. I was having trouble finding a solution for slow turn signals on my 92 F-250. Finally tried the forum, and after wading though the good, bad, and garbage posts, I found one suggesting using an LED flasher instead of the OEM flasher given that it uses the actual voltage instead of heat in the line to break the circuit. I googled led flashers and found one that would be worth a try. It worked and I put in my first post after registering on the site. It included the part number, cost, source, and how well it fit, and worked along with my vehicle and details of my search. My post appeared for a few hours and then was removed along with a nasty gram from the moderator ( IB Tim) claiming I was the "spammer of the worst kind," and that I was banned " for ever." I pointed out to them that I used an F-250 header thread for the same vehicle as my guide for the post since it contained the exact same elements that I put in my post. That being the source, part number, name and cost. I still have not heard back from them. You try and do other readers a service to save them wasted time under their dash, and for your efforts you get a sarcastic email and are banned from the site by the moderator. I read the post rules and this was spam imo.
Roger in Tucson
sorry about your problem. Your first post fit the criteria of most spam. Additionally the person that banned you is not a normal moderator but someone that watches over the site from the main office. Again, I’m sorry, stuck around and hopefully you will be treated better.
Old Dec 15, 2019 | 10:33 PM
Roger - are you referring to FTE or this forum?
Old Dec 18, 2019 | 10:13 AM
JackandJanet's Avatar
glc (and everyone else) - I'm pretty sure he's referring to FTE. I KNOW I did not remove a post of that type from him, nor would I, after reading it. I'm certain Bluejay and Patman would see such a post the same way. Bluejay's comment referred to the way our automatic spam filters function, they don't ban people, but they DO bring questionable posts to our attention.
Please notice also, that Roger has not been banned from this site. He has a "0" post count due to posting only in General Discussion.
And, I think YOU know all this. My comments are for other members that may have questions about how we do things here.
- Jack
Old Dec 18, 2019 | 12:03 PM
FTE Bad Experience
To GLC, heck no, it was not this site. To Jack and Janice, Thanx for the comment and confirmation. It restores my faith in peoples good judgement.
Roger
