Headlight Assembly Trouble
Old Feb 10, 2011 | 04:44 PM
miketoug's Avatar
The assembly for the passenger side headlight is stuck. I pulled the release levers and its just plain stuck. Any tips on how to remove it without causing damage?
Old Feb 10, 2011 | 05:12 PM
SSCULLY's Avatar
what MY truck ? Sounds like a 97-03 MY, but do not like to guess.
If it is a 97-03 MY, are you pulling the release levers up far enough ?
Old Feb 10, 2011 | 05:21 PM
What year of truck??????
Did you remove all the retainer bolts?
Old Feb 10, 2011 | 06:37 PM
miketoug's Avatar
sorry, new to the forum. its a 2001.
Yes, but the one on the right alignment screw is turned to the side.
Old Feb 10, 2011 | 07:40 PM
dirtyd88's Avatar
even if the screw looks turned, it should still come out.
give it a good wiggle while pulling it out, and have someone push on the back of the alignment screws while you pull. sometimes they just need a little help.
Old Feb 11, 2011 | 10:23 AM
miketoug's Avatar
Just want to thank you all. It's fixed!! Your advice was very helpful and it slid out like a greased monkey! Glad I found this forum!
