4x4 trucks easier to sell than 4x2 trucks?
Should be about as many looking for a 4X2 as there are looking for 4X4... if the primary use is hauling materials around on highways and paved roads and towing around on highways in the more temperate climates then who wants to haul around the extra weight and drag of that extra axle. It often gets you lower gas miles and it subtracts from your total towing or hauling capacity.
But if your moving stuff around the farm a lot and in areas often affected by snow then its a plus.
But there are probably far more people not needing 4X4 than there are KNOWING they don't need it. I finally got to the point I don't invest in it anymore.
You will normally get more for a 4x4 truck than a 4x2 truck but you pay more on the front end so it is a moot point there.
It depends where you are located but that isn't a guarantee. You can sell a 4x4 truck to a larger market for the most part. That said many will buy a 4x2 even in the snow belt and they will be just fine.
Most people don't need 4x4 but it's good to know you have it! Just in case.
I recently bought a 2010 F150 Lariat but declined the 4x4 option.
The dealer stated that every truck on thier lot was a 4x4 but I chickened out on the extra cost for a 4x4. Hopefully I will hold onto this truck until its paid off but I'm wondering how hard it will be to sell a non 4x4 truck?
hopefully someone else will be the same way when you try to sell the truck....
I got 18500 for mine. 2006 lariat 4X4. had 75000 miles on it. Sold it on the lot in two weeks for $20900 It probably had more options, but in Missouri I think a 4wd is a little more popular. Also i like the way they sit better, may only be a couple inch block in the back. Also just because it doesnt snow or rain or whatever the reason may be the one time you will need 4wd you wont have it. Thats worth it to me. some trucks will get hung up in wet grass and you are done nancy!!
This year i think Texas has gotten more snow than Michigan total.
