wireless networking help
Old Aug 8, 2010 | 09:53 PM
chrism9232's Avatar
my tv stand need internet for my xbox 360 and my directv dvr. the directv dvr uses the internet for downloading the ondemand some of it is in 1080p. it need alot of bandwidth and i can watch my dvr on my pc. im trying to hook it up wireless so i can get the wire off my floor. i was looking at buying a wireless bridge for my tv stand. will that work? i have a linkses wireless g routers. this is what i was looking at. http://www.newegg.com/Product/Produc...82E16833127256 . would this be the best way?
Old Aug 8, 2010 | 10:18 PM
greencrew's Avatar
I like the Linksys PLS300 but you may want to go with the new e-series
E1000
Old Aug 8, 2010 | 11:09 PM
chrism9232's Avatar
E1000
i already have a router i need a bridge i think
Old Aug 9, 2010 | 08:16 AM
greencrew's Avatar
That is a four port bridge. I have three computers and a networkable printer plugged into my bridge.
Old Aug 9, 2010 | 08:51 AM
If you need a lot of bandwidth, stick with the cable.
Old Aug 9, 2010 | 09:58 AM
MGDfan's Avatar
I would tend to agree.
Is this streaming, or simply store & forward? If it's the former, be advised that HD content requires at least 40 Mb/sec to enure consistent quality.
Wireless G won't cut it in this ( streaming) case - you'll need to get N routers and configure for 300+ Mb/sec (40Mhz channel widths, etc).
If it's simply download then stream from local storage, the only effect will be on the time it takes to download.
BTW - Don't cinfuse bandwidth with throughput - two different things.
MGD
Old Aug 9, 2010 | 03:31 PM
F150 Power's Avatar
I would personally get some cat6 cables and do it wired. Wireless isn't the same for gaming and videos etc. Here's a cheap place to get the cables, I buy mostly all of my cables there.
And if you need a router you can never go wrong with the WRT54GL with DD-WRT or Tomato firmware. The firmware can turn it into a $300 router with the right configuration.
Old Aug 10, 2010 | 03:19 PM
chrism9232's Avatar
there really is no way to run a wire there. i have watched my dvr over wireless on my laptop. it worked fine. here is the software i use. http://www.directv.com/DTVAPP/conten...ogy/directv2pc will that bridge work? the directv ondemand downloads to the hard drive of the dvr
