Wireless Network Help
Old Aug 3, 2010 | 09:35 PM
dirtyd88's Avatar
I need some help out from any tech gurus here on the site.
Does any one know if it is possible to setup a wireless network in my apt that is fed off another wireless network put out by my complex? Or do all routers need a LAN cable to kick out a wireless signal?
If it is possible, what would I need to do to make it work?
Old Aug 3, 2010 | 09:39 PM
044WD's Avatar
If you are going wireless without a direct connection in your apartment it would have to be very close. Even the best Wireless routers are around 300 feet. On top of that it would have to have no WEP key or password or they would have to be willing to give it to you. Sometimes you can get lucky and somebody in an apartment around you doesn't secure their connection and you can bum off of it but it is normally much slower due to the distance.
Old Aug 3, 2010 | 09:56 PM
06F150STX's Avatar
So true. You would need a WEP or a Passphase code. Good luck.
Old Aug 3, 2010 | 09:58 PM
dirtyd88's Avatar
Well the wireless signal I get in my room is sketchy, and i seem to get the best signal when standing by my window. our wireless is unsecured, so I can easily tap into the signal.
I just want to know if I will need a wireless card for the router or not, and what all I'd have to do to set it up.
Also, even though the complex wireless is unsecured, can I secure my signal on my network?
Old Aug 3, 2010 | 10:03 PM
044WD's Avatar
If you are picking up on the network with your current wireless card and it's unsecured you should just be able to connect to it but it may go in and out. You don't need a router if your wireless card is already picking up on it. You can't secure your connection because you are just tapping into the main connection. You don't have a connection for anybody else to pick up on, anybody else who is using that connection is taking it from the same place you are.
Old Aug 3, 2010 | 10:49 PM
MGDfan's Avatar
http://lmgtfy.com/?q=how+wifi+repeaters+work
Be advised - No way to secure it, though ...
MGD
Old Aug 3, 2010 | 11:11 PM
What you need is a repeater. Place it where you get the best signal. I'd probably get a Linksys WRT54GL router and load DD-WRT firmware on it and turn it into a repeater. I believe what you would want would be the "client bridge" mode.
Old Aug 3, 2010 | 11:32 PM
dirtyd88's Avatar
that sounds like what i'm looking for. just trying to bring in the best signal from the source and then repeat it through my apt so I have a stronger signal.
thanks glc, I will look into that.
Old Aug 3, 2010 | 11:38 PM
MGDfan's Avatar
yer welcome
dirtyd88's Avatar
so which one do I download?
Old Aug 3, 2010 | 11:39 PM
dirtyd88's Avatar
Originally Posted by MGDfan
yer welcome
thank you too MGD, i read through that, and just forgot to throw your name in there. :o appreciate it much sir.
and thanks to everyone else too
Old Aug 3, 2010 | 11:41 PM
dirtyd88's Avatar
whats the difference between a Linksys WRT54GL and Linksys WRT54G??
Old Aug 3, 2010 | 11:42 PM
MGDfan's Avatar
NP - thought y'all wuz pissed due to the delivery
glc will walk you through the DD-WRT stuff
MGD
Old Aug 3, 2010 | 11:49 PM
dirtyd88's Avatar
ok. now i need to find a router to use on CL. Will I bee ok using a used router?
Old Aug 3, 2010 | 11:52 PM
jbrew's Avatar
The WRT54"GL" is equal to WRT54"G"/ v4. They are likes.
