lookin for a new truck, tips on 4x4
Old Jun 18, 2010 | 07:25 PM
f150fella08's Avatar
what do i need to look for in a 4x4, and how can i tell if the 4x4 works, jack all 4 tires off the ground and put er in 4 high and drive?
Old Jun 18, 2010 | 07:46 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
How about a simple test drive in 4 hi then 4 low, Jacking it up seems weird.... lol
Old Jun 18, 2010 | 07:53 PM
BlueOval_Man's Avatar
Trust me you can tell when your in 4WD.
Old Jun 18, 2010 | 09:13 PM
Djacobs28056's Avatar
As long as it's got a really cool "4x4" decal on the side... you're good to go.
Old Jun 18, 2010 | 09:28 PM
4wd150's Avatar
. thats the most reliable check you could possibly do
Old Jun 18, 2010 | 09:29 PM
MTM Ford's Avatar
A good indication that it's a 4x4 is that it has a little lever stickin out of the floor. Maybe a button on the dash. If it has one of those just buy it.
Old Jun 18, 2010 | 09:38 PM
kp02-150's Avatar
I guess since I took my 4x4 stickers off my 4wd disappeared
Old Jun 18, 2010 | 09:39 PM
4wd150's Avatar
yeah if its close by to a gravel road/driveway you could test it out there. make sure you try both high and low, to engage low range, incase you didnt know, put the truck in neutral with foot on the brake and then shift into low, or turn the ****/button whichever it may have. and if u want to make sure its engaging/disengaging, place in 4wheel and kinda punch it, youll be able to tell if its in 4wheel, then take it out of 4wheel and punch it, if only your rears spin then your disengaged. kinda easy test you could do to just see if it even works
Old Jun 18, 2010 | 09:57 PM
I was mainly answering this question...
Old Jun 18, 2010 | 10:25 PM
Joethefordguy's Avatar
take a 2WD and a 4WD and drive them both over the crappiest terrain you can find until they're stuck.
the one that needs 50 feet more of tow chain for the tractor to recover it with is the one with the functioning 4WD.
if they use the same length, the 4WD isn't working.
Old Jun 18, 2010 | 10:30 PM
4wdf150 thank you for actually answering my question.
when i go to a dealership i cant really be like hey, let me try to drive through this pond and when i get stuck and put it in 4x4 and see if i can get out
Old Jun 18, 2010 | 10:31 PM
sorry if i asked the question wrong, figured someone would have enough sense to know what i was talking about
Old Jun 18, 2010 | 10:36 PM
4wd150's Avatar
yeah its understandable when buying a truck from a dealer, you cant ask to take it wheelin lol. i mean just check to see if the dash lights come on saying your in 4 wheel drive, and if you turn the wheels to one side or the other to about full lock, you will feel it thumping kind of. could just do that quick in the parking lot if all other options are out of the question
Old Jun 18, 2010 | 10:44 PM
and i could just do a neutral drop and 4 high and see if the front wheels spin too
dont think they would go for that though huh lol
Old Jun 18, 2010 | 10:59 PM
PJB4x4's Avatar
Put it in 4wd and drive in a circle and you should feel it fighting you a bit. Then put it back in 2wd and do the same thing and it should be easier.
