Question
Old May 11, 2010 | 05:20 PM
MaTT CooK's Avatar
Question
ive got a 1993 ford f-150 straight 6..ive been having problem starting it up like ill crank it up and just keeps going and doesnt start i have to pump the gas pedal alot to get it going i put new fuel filter on it and it didnt do anything what do you think is wrong?
Old May 11, 2010 | 05:48 PM
Green_98's Avatar
Does it run or not? How long does it take to crank? Does it stumble, misfire, blue/black smoke, etc? Do you get a check engine light on your dashboard?
Keep in mind you need 3 things for combustion:
1. Fuel
2. Air.
3. Spark
If it wont crank, you have problems in 1 or more of those areas:
Fuel: Fuel Pump, fuel filter, clogged fuel lines, etc
Air: Clogged filter, sensor bad, etc
Spark: Disconnected plug wire, bad plugs/wires, bad coils, etc
I would start by pulling all 6 spark plugs and putting new plugs and wires on the truck. Then, listen when you turn the key on and see if you can hear the fuel pump priming the fuel lines. Pull your intake apart and pull the filter out, letting the truck breathe openly while you crank it.
