Dishwasher Installation
I'm pretty handy around the house but have never hooked up/disconnected a dishwasher.
I found a great deal on a new one but, want to dodge the installation costs ($100'ish) if it is practical.
Doesn't seem like there's much to it... anyone done this? Should I worry at all?
Make sure you have all the fittings for the washer side and the drain stuff etc, and ensure it's dead-level.
Install a local water shutoff valve - you'll thank yerself later, lol.
Separate 15A fused/breakered feed also highly recommended.
Check fer an install manual online - here's one - they are purty similar: http://kitchen.manualsonline.com/man...77_series.html
Oh - and be sure to turn off the water supply
MGD v5.0
Thanks, guys. I kind of figured it'd be CAKE but, I was just a bit standoffish about it. We have a 'contractor special' in our house that sounds like it's going to take orbit when it's running. We really need something that's more quiet and does a better job considering that we're doing 4+ loads per week.
I've done a couple too, Brad. As the others say, it's really very easy.
I agree on the local water shutoff valve if you don't already have one and I'd recommend a braided stainless steel hose for the supply, instead of the normal "rubber" one that comes with the unit.
There are new shutoff valves that are the "quarter-turn" ball valve kind. Those are great anytime you have to replace a sink or toilet valve too.
- Jack
- Jack
- Jack
- Jack
MGD v5.0
^ what they said. If you're replacing an existing one, it's a snap. They haven't changed in the past 20 years, 'cept get quieter, Water in, water out- dedicated power line. Drop the breaker, shut off the water, pop a beer. (do yourself a favor, get a good stainless steel braided supply line.) Remove old unit. Install new lines, hook up electric, drain hose, anchor it down, pop a beer. Clean up, impress the misses, pop a beer. Done!
4+ a week, thats all. In my house we do an average of 9 loads a week. Thats why I went out and spent almost a grand on a bosch dishwasher, quietest I've ever heard. You can stand right next to it and not even know its running.
Ehh... maybe we run more than 4. I probably don't have the full scope of what we actually do since I'm not normally 'managing' that department of the household. LOL! I do, however, have a 2 (almost 3) year old that certainly produces her fair share of dishes.
We may be closer to 8... *shrugs*...
I'm scoping one in the $800 realm but, as a guy that does a significant amount of work for GE, it'll probably be from them... Made in the USA (in Building #3 at Appliance Park, Louisville)....
This might be too basic but nobody said anything about the "tip-out" screws under the counter. Pop the door open and there will be 2 of em going straight up, and they are a must when it goes back in. Also depending on your floor you might have to lower the levelers to get it out. Those are the only issues I had with my first one.
Piece of cake like said earlier.
Thanks, jgger... I appreciate that input. I have noticed that it's secured in with the two screws that you mentioned... I think it'll slide out as there's a tad of room between the top of the unit and the counter....
