Look what I got for free.
Old Mar 23, 2010 | 01:17 AM
  #31
migdaddy's Avatar
start with that little guy, then move on to the supercharged seadoos. 215 HP intercooled.... mm mm good.
Old Mar 23, 2010 | 01:22 AM
  #32
W.L.B's Avatar
My dad has the supercharged yamaha FX SHO. Its ridiculous the power that thing has. I have the Fx HO and I thought mine was too much. Damn I cant wait till summer time.
  #33
b2therad's Avatar
Yes sir!!!
We have two of them! 2003s but only one of them was used for racing
Old Mar 23, 2010 | 06:24 AM
  #34
Tumba's Avatar
With the age of that ski, and the number of years it has set up. I would bypass the oil injecter pump, and run premixed 30/1 in it. Those pumps are a pitfall for the skis. Then I would just take the Carb of and get it rebuilt at a shop. The other thing is the the gas system has to be sealed and running pressure from the exhaust, with a checkvalve to hold the pressure. Some new sparkplugs. It will probably fire up.
Then when you get it running, a lack of HOT starting , would indicate a jug rebuild.
I have own several over the years, and the oil pumps do fail frequently, causing a lack of lubrication. After that I just always ran premix in them.
I would probably replace the rubber water lines too. They're probably pretty dry.
Over the years I've had Stand ups- 300, 440, 550, and a 650 SX, and in sitdowns, I've had an X2, a 750zxi, and a 900. I sure miss the standups the most, but the sit downs are alot of fun also.
