Herters ammo?
Old Jan 14, 2010 | 02:02 PM
Frank S's Avatar
Originally Posted by kingfish51
According to this, they are polymer coated steel cases, assuming these are what he is buying. Also Russian manufacture.
http://www.cabelas.com/cabelas/en/te...233&hasJS=true
I would recommend staying away from steel also. Unless it's a gun you rarely shoot. Steel-cased ammo is known for causing excessive wear.
Old Jan 14, 2010 | 05:54 PM
Wookie's Avatar
I'll use the cheap steel stuff in cheap guns (SKS etc). The coating does make them much slicker and will not wear the chamber as bad as bare steel will. Most of the steel case ammo was made in eastern bloc countries where cost and reliability was the most important factor. Steel is great for this but rough on the weapon. Brass is still the best and this is all my better weapons will see. Brass is softer than steel and will grind and wear out the chamber under normal use.
Old Jan 14, 2010 | 06:04 PM
donbeeler49's Avatar
IMHO ammo is like picking a ford over a chevy. Everyone has there opinion. Based on personal experience I will never use Wolf in anything. I've had problems with jamming and it's extremely dirty. My AR will shoot PMC, Federal, Black Hills, Hornady and others no problem. It doesn't like Wolf.
Old Jan 14, 2010 | 06:49 PM
jmeyerholtz's Avatar
Isn't the chamber on a rifle hardened? If so the mild steel from a case isn't going to do anything to a chamber.
Old Jan 14, 2010 | 07:04 PM
Frank S's Avatar
Actually, even hardened steel will wear faster with steel casings. It is a minimal increase, but like I stated above, if it's a weapon you care about, I would stick to brass.
Old Jan 14, 2010 | 07:36 PM
Originally Posted by ranger81
That's a name I haven't heard in years. They used to have a retail outlet in Glenwood MN as well. I remember going there as a teenager and looking at the snowmobiles they had on sale there.........
I remember Herter's snowmobiles -- I think they were red, weren't they? If I'm not mistaken, they were actually Johnson snowmobiles that were private-labeled for Herter's.
My best friend had his first lawyer job up in Glenwood -- made many a weekend trek up there from the Twin Cities to get blasted at the local taverns. He lived in an apartment above the "Pizza Ranch" restaurant so the biggest challenge we had getting home after a night of "tilting them back" was scaling the rickety steps that led to the second floor of the building.
He dated Jodi Huisentruit (sp?) (that news anchor who disappeared down in Mason City, IA) while he was up there and she was a reporter for a station out of Alexandria.
I have many funny memories of that place.....
Old Jan 14, 2010 | 09:33 PM
Thats why they coat it with polymer, The Steel never makes contact with chamber.
Old Jan 15, 2010 | 12:51 AM
Frank S's Avatar
If you're happy with this: http://www.theboxotruth.com/docs/edu18.htm , happy shooting.
Old Jan 15, 2010 | 05:26 AM
I've never had a problem like the what was said in the link. One a year me and all my cousins get together at me and my brothers cabin and shoot. we will go threw a few thousand rounds mostly .223 from either AR-15's or Mini 14's. we tend to shoot a broad range of ammo, we will go from 30-60 rounds of wolf to 30-60 rounds of UMC. I have never not had a shell not come out. I know wolf can be very dirty, and some wont cycle correctly in some guns but from my experiences with it I see no need to stop using it.
Old Jan 15, 2010 | 02:51 PM
shifty_85's Avatar
not sure what kind of 9MM ammo you need but ive always found Cheaperthandirt.com to be well the cheapest.
here is 55 links to 9mm ammo on there site. if thats not the right kind go up to the keyword and type in what kind of 9MM you need.
http://www.cheaperthandirt.com/Searc...s&num=10&q=9mm
