Reality check on car-care myths
Old Dec 18, 2009 | 06:49 PM
JRVicHammer's Avatar
Originally Posted by bjp207
If you all live in a place where it gets real cold in the winter and your truck is parled outside you'll see why you have to warm it up. Half the mornings I get into my truck I can't see because of frost on the windshield
That's why I moved to a new house with a garage. My truck was always parked outside at our last house because it wouldn't fit in the garage. I would let it run then only while I was scraping the windows off with an ice scraper. If I waited for the truck to warm up enough to clear the windshield on its own I would have had to start the truck 45 minutes before I went to work.
Old Dec 18, 2009 | 08:14 PM
greencrew's Avatar
Safety first! I do let my truck warm up if I have to scrape the windows.
Originally Posted by avfrog
^ which is why they say excessive idling is considered extreme conditions for engine oil changes...
That is also why I think a one year old truck with 30K is a cream puff. If they drive that many miles in one year, they're not getting many cold starts in.
Old Dec 18, 2009 | 08:19 PM
Another myth is turning off the engine to save gas to go in the convienence shop to get coffee... if you turn the engine off and back on, you'll burn more gas because the engine goes through it's warmup cycle again even it's just for a minute or two -- the engine runs rich, meaning it is dumping more raw fuel in until it reaches it's stoichiometric combustion ratio.
If I'm out, I rarely turn the truck off... even if I go shopping in Wal*mart...
Old Dec 18, 2009 | 08:22 PM
avfrog's Avatar
I thought was true, but I didn't know for sure.
Old Dec 18, 2009 | 08:33 PM
mtnbikes's Avatar
I see your point, but at what time frame are you really saving gas by keeping it running vs restarting it...1min...5min?
Old Dec 18, 2009 | 10:46 PM
MTM Ford's Avatar
The main reason I let mine warm up is to let the oil get circulated. I don't really wanna start it and take it to 1500-2000 rpms when it's cold.
Old Dec 18, 2009 | 11:17 PM
Tumba's Avatar
In the instance you refer to here, it is more of a lubrication issue than fuel. Killing and engine for 5 minutes or so at a time, causes dry starts on hot parts that have no oil on them for a second or two untill the oil pump gets the oil moving. Unless you do it frequently, it's not a huge deal. But if you dry start several times daily. The hot starts take a toll on the wear inside the engine.
Old Dec 18, 2009 | 11:20 PM
scotyg's Avatar
Myth: Dishwashing and laundry detergents make a good car wash.
Reality: Detergent can strip off a car's wax finish. Instead, use a car-wash liquid, which is formulated to clean without removing w
who honestly believed that?
Old Dec 18, 2009 | 11:25 PM
Tumba's Avatar
The powered laundry detergents have abrasives and fillers in them such as ground up peanut shells(as one example) and it will casue tiny scratches in your clearcoat and or wax. I think the liquid one just have harsh detergents.
I use dish washing liquid quite often myself.
Old Dec 19, 2009 | 09:36 AM
greencrew's Avatar
'A "cold start" is a "dry start".'
Also note:
'Q. When I start my engine, I let it warm up slowly by idling before I drive away. Doesn't that solve the problem?
A. No. The only way to totally eliminate "dry start" or "cold start" wear is to achieve oil pressure and lubrication before start-up. '
Old Dec 19, 2009 | 10:02 AM
Tumba's Avatar
Also note:
I'm actually refering to cranking one dozens of times a day, it is better to leave them running.
I have several delivery cars, and the engine lasts longer if we do not turn them off and on when they are away from the hub.
Yes a cold start is a dry start.
Old Dec 20, 2009 | 05:35 PM
bambo2888's Avatar
look at your hood in direct sunlight or under florescent lights and tell me what you see around the reflection of the light source...
my prediction will be swirl marks in a diminishing clear-coat...
Old Dec 20, 2009 | 08:02 PM
f150fella08's Avatar
i change my oil at 2500 because it takes me about 4 months to get there..and thats enough seeing as i make about 80% short trips.
Old Dec 20, 2009 | 08:14 PM
MTM Ford's Avatar
It takes me about 4 weeks to get to 2500 I's usually around a month to month and a half when I change my oil.
Old Dec 20, 2009 | 08:17 PM
my work is about 4 miles away from my house
