Kids ATV help
Kids ATV help
I just brought my stepson's little 50cc atv home from his other house . It is getting spark , gas and has compression but will not start . It is a Kazuma brand . What could be going on here ? Thanks
It is electric start , I thought about the kill switch , but wouldn't that kill the spark ? It is getting spark (maybe not enough) not sure how to test that . Getting gas , has compression , timing chain is good . That is all I could think of . Seem like if it is electrical it wouldn't get spark , not sure though .
Same here . lol
I hate this dang little headache , was great up till this crap happened . Read that they are bad on the intake cracking , but not the case on mine .
Was trying to figure out how to add a lift kit to it since it has no front suspension . If I ever get it running I will try and make up something to lift it up . That would look crazy .
Same here . lol
His broke down 2 years ago at his real dads house and he just put it up until this week he asked if I wanted it to fix and have here for the boy to ride on my farm . I just want to get it fixed asap . the dad is about 250 and he said he rode the hell out of it and it pulled him good .
Done that already . To me it should start as it is getting what it needs to fire up . Gas and spark . The timing chain is good , compression is good . What else would cause this I am lost . Going to talk the supposed to be best around ATV tech after work Thurs or Saturday . Just don't want to put too much into this thing as I can buy a whole new motor for like $300
What kind of carb is on it? Have you guys tried the old tap test on the float bowl to see if its stuck? The other thing that might have happened is there may be varnish in the float bowl and is mucking things up. There should be a screw or nut on the bottom of the bowl try draining the float bowl and see if you get dirty gas.
Float and carb are clean and good , that was the very first thing I checked when I got it here . Never been in water . It died while he was riding it , I wasn't there so I have no clue as to what it done .
