winter time-heating advice
Old Oct 19, 2009 | 05:39 PM
  #31
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Hi i have a st croix pellet stove and it heats my whole house to 74 degrees all winter for ~200 a month. Try one you will like it... makes me happy!!!. We get real cold here -20's at times... highs -5-10 above.
Old Oct 19, 2009 | 06:17 PM
  #32
openclasspro#11's Avatar
Originally Posted by JJDH
let me rephrase,, i am far from a hack. i am a perfectionist with my work,m i am by the book and good at it, with that being said i have sized enough systems and designed them that i can be really darn close just by walking through. when i do replace equipment i do the load calc sheet, on the computer i dont feel like typing a book, so you should kno what i mean, it isnt rocket science. i am not cheap, when i do get out on my own my prices will be towards the high end, no lo ball bullsht. i am working on my contractors license... i would still bet a nickel u go load that house mentioned above and that will be what it needs, of course no one has seen it
my point- we aren't there-exactly why i didn't throw out a size-btw - did you use a design condition for ohio on that equipment size recommendation?, what if he has a boat load of windows facing the load of the sun in the afternoon?i'll take that bet and raise you $9,999.95
Old Oct 19, 2009 | 06:24 PM
  #33
anemometer....would be the proper tool..imho
for outdoor wind readings-yes-at least that's whats used by my local news crew station's weather dep't.
velometer in residential and commercial applications
Old Oct 19, 2009 | 07:07 PM
  #34
Camarothatcould's Avatar
block heater
Old Oct 19, 2009 | 07:53 PM
  #35
JJDH's Avatar
ok.....tomato tomatoe....http://www.mannix-inst.com/Departmen...ow-Meters.aspx
Old Oct 19, 2009 | 07:55 PM
  #36
JJDH's Avatar
of course, thats what the sheet is for, i did state that we havnt seen it, also that the windows do matter
Old Oct 19, 2009 | 08:12 PM
  #37
by knowing vp ,sp, you will know tp and will figure out cfms,let's get back to my original point-unless an actual load calc is done for the building upon seeing it , with all contributing factors taken into account,thowing a size out for a house in texas is not the same say for that house in minnesota...just walking into a house and throwing a number out there is not accurate.i've been in the field for 23 years,and while i may be good in guessing a size,i'll calc it everytime....
Old Oct 19, 2009 | 08:20 PM
  #38
Tumba's Avatar
How do you calculate the density of the British Thermal unit?
Does the relative humidity play a major roll?
Old Oct 19, 2009 | 08:28 PM
  #39
JJDH's Avatar
ur getting in very deep now buddy....too much to explain ....
we have had 4 hr classes on that stuff
Old Oct 19, 2009 | 08:34 PM
  #40
maybe we can discuss the static regain theory,or the importance of removing the latent before we have a measure sensible heat drop?lol-let's keep it simple for the members to be able to understand...
Old Oct 19, 2009 | 08:35 PM
  #41
JJDH's Avatar
ur supposed to calc it. i wouldnt argue that..
Old Oct 19, 2009 | 08:41 PM
  #42
80,000 btu furnace, 3tons a/c , go with amana, trane or american standard,
funny , ran into customer with similar house -2175 sq ft under air 2 story- 60k and 2 1/2 ton did him fine-only time he goes full fire is coming out of nite setback and the few days we were 10 degrees and below in the last 4 yrs since install=i'd say it 's a lil colder here in pgh pa than graham texas, but i could be wrong...
Old Oct 19, 2009 | 08:42 PM
  #43
my problem is i eat sleep and breathe this ****, guess that's why my company is such a success.
Old Oct 20, 2009 | 01:04 AM
  #44
hoss66's Avatar
I have an older house and i dont think the walls are insulated because i have added a couple outlets in the walls and never saw any insulation. The house is all stone exterior and the interior is drywall over plaster and is about 2 inches thick total. How would i be able to insulate the walls without tearing it all down. I know the old houses with siding can be drilled and filled from the outside but i dont think that would work very well with the stone.
Old Oct 20, 2009 | 07:18 AM
  #45
JJDH's Avatar
like you said we are talkin texas, the house will be cookin alot, o, well the bottom line is a calc should always be done.... i cant wait to get goin on my own
