Two new recalls for '97s
And one for the 2000s:
Report Date: September 12, 2000 07:11:44 PM
NHTSA CAMPAIGN ID Number: 00V228001
Component: INTERIOR SYSTEMS:ACTIVE RESTRAINTS:BELT BUCKLES
Manufacturer: FORD MOTOR COMPANY
Mfg. Campaign #: 00S21
Year: 2000
Make: FORD TRUCK
Model: F150
Potential Number of Units Affected:
Manufactured From: To:
Year of Recall: '00
Type of Report: Vehicle
Summary:
Vehicle Description: Passenger vehicles, light duty trucks, sport utility vehicles, and mini vans equipped with TRW seat belt buckle assemblies. The buckle base of these seat belt assemblies were not properly heat treated and therefore do not pass the load bearing requirement of Federal Motor Vehicle Safety Standard No. 209, "Seat Belt Assemblies."
In the event of a vehicle crash, the occupant may not be properly restrained.
Ford has not yet provided a remedy for this campaign. Ford has not yet provided an owner notification schedule for this recall. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact Ford at 1-800-392-3673. Also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236).
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil and filter, Build date 7/00
[This message has been edited by Dustoff (edited 09-13-2000).]
Year: 2000
Make: FORD TRUCK
Model: F150
Year of Recall: '00
Summary:
MOVEOVER, I just checked the recalls from here and came across this for 97 F-150's:
NHTSA CAMPAIGN ID Number: 00V231000
Component: FUEL:FUEL LINES FITTINGS:NON-METALLIC
Mfg. Campaign #: 00S22
Year: 1997
Make: FORD TRUCK
Model: F150
Potential Number of Units Affected: 670509
Manufactured From: NOV 1995 To: AUG 1997
Year of Recall: '00
Summary:
Vehicle Description: Light duty pickup trucks. The front fuel line assembly could have a hole rubbed through in one of two locations. The first location is below the fuel rail connection where the flexible hose is crimped to the steel tube. The bracket that attaches the front fuel line to the transmission could have been bent during assembly. The second location is at the rear steel tube section forward of the rear bracket. During installation the rear steel tubes of the front fuel line assembly could have been bent downward. In vehicles equipped with a manual 4xz4 transfer case shifter, the shifter linkage may contact the steel tubes as it is being shifted between 4H, 4L, 2L and Neutral.
This condition could result in fuel leakage. Fuel leakage in the presence of an ignition source could result in a fire.
Year: 1997
Make: FORD TRUCK
Model: F150
Year of Recall: '00
Summary:
