Need some help with the IPOD Touch
Old Feb 24, 2009 | 10:50 PM
johnnyd2723's Avatar
My wife got me one of these for my birthday and I can't get the darn thing to do anything. When I turn it on all it shows is a usb cable with a arrow pointing at a icon that says ITunes. I downloaded the itunes but it couldn't finish configuration because it said a dialog box was open. That has something to do with my windows operating system I believe. This hasn't been right since I took my laptop to Comp USA for repairs.
Any thoughts?
Old Feb 24, 2009 | 10:59 PM
Barrett's Avatar
If im not mistaken you have to first plug it into your computer for it to configure and do who knows what. But until you plug it in and get Itunes working I think you are kind of stuck.
Or go plug it into a friends computer to get it working first.
Old Feb 24, 2009 | 11:02 PM
mxracer49's Avatar
What if you hold the power button down for like a second? The circular button at the bottom. That should take you to the main screen.
Old Feb 24, 2009 | 11:12 PM
When I plugged it into mine my pc it recognized it as "new hardware ipod" and offered me options to choose how I want to view it. None of the options worked. I am on a Sony Vaio 03' model. Gettin' a little old maybe?!?!
If I hold the pwr button then two options come up 1. CANCEL or 2. Slide to power off. This IPOD doesn't have the round controller on it. It's the touch screen model.
Old Feb 24, 2009 | 11:16 PM
mxracer49's Avatar
The power button is the button I'm talking about. There's also a power button on the top that completely shuts it off. What does it do if you cancel?
Old Feb 25, 2009 | 07:57 AM
BlueFlareside's Avatar
http://support.apple.com/kb/HT1345
1. Install iTunes
Before you connect your iPod to your Mac or PC computer or use it, you must install the latest iTunes software.
2. Connect and Set Up your iPod
Charge your battery by connecting it to an Apple iPod Power Adapter or connect your iPod to a high-power USB port —one that's located directly on your computer—to ensure that your computer charges your iPod battery. (If your computer doesn't seem to recognize your connected iPod, wait about 30 minutes to allow the iPod battery to charge before going further.)
3. Fill your iPod and iTunes with Music
Once you finish the set up, iTunes will open. It will then either:
Automatically start filling your iPod with music from your iTunes library (if you set iTunes to automatically update your iPod)
OR
Allow you to pick and choose what music, videos (if you have a Fifth Generation iPod), audiobooks, and podcasts to add, if you opted to manually manage music on your iPod.
To manually add content, simply drag any file from your iTunes library or playlist to your iPod icon in the iTunes Source list. If you're using iTunes for the very first time, you'll need to add some music to iTunes first, such as songs from your own CDs or music already on your hard drive.
Old Feb 25, 2009 | 08:01 AM
06F150STX's Avatar
sounds like it might needs to be reset. go to www.apple.com/support it might can help you out.
Old Feb 25, 2009 | 08:23 AM
mxracer49's Avatar
Also, it may have been disconnected from your computer before it was done synching. Try connecting it again. Before disconnecting eject it with the little arrow icon beside the iPods name in itunes.
Old Feb 25, 2009 | 08:28 AM
Did you completely install iTunes before connecting? Read step 1 in the instructions.
Old Feb 25, 2009 | 08:49 AM
Thanks guys for your help.
I brought it to work with me and everything went smooth. For some reason my home pc doesn't want to play with the ipod which is a bummer. I'll have to take a day off and come in just so I can familiarize myself with this thing.
Thanks again
Old Mar 10, 2009 | 08:39 PM
kpiskin's Avatar
I lamented over leaving Verizon for AT&T to get an iPhone and ended up going for an iPod Touch instead. I really like it and now that I have installed the Brandmotion in the truck I am getting a lot more use out of it. My only issue now is placing it somewhere in the truck and not having the cord hang out of the ashtray. I put it in the glovebox like the company recommended but the touch and iphone are a little too large to fit in the glove box cleanly.
Old Mar 10, 2009 | 09:41 PM
mblouir's Avatar
One question...is your Sony 64-bit? The Ipod Touch has no 64-bit compatibility, so any Windows users with 64-bit computers cannot sync with iTunes. I was extremely angry when I learned this because I just bought a new laptop that is 64-bit. If I didn't still have my old laptop then my Touch would be about as great as a brick...
edit-Did a bit of research and I don't think sony even supports 64-bit in any of their laptops, let alone an '03, so this probably isn't your problem. If your computer is 64-bit, however, take this as a heads up!
Old Mar 10, 2009 | 11:53 PM
bigdog87's Avatar
Yeah in order to somewhat activate it, you must run it through the Itunes like startup kinda doodad but after that they are fun!
Old Mar 11, 2009 | 03:58 AM
inurok's Avatar
Any thoughts?
One of the reasons they went out of business around here. I worked at a CompUsa for 5 years & I would never bring a computer there for repairs even though your problem is software related not hardware.
