f450 psd problem
Old Jan 8, 2009 | 04:22 PM
azmidget91's Avatar
f450 psd problem
ok so my dad has a 05 f450 with the 6.0 in it and it will start then about 20-30 minutes later it would just die, it sounds like it is running on 6 cylinders then just dies, and wont start untill it is cold again, sometimes it doesnt start cold either.......what could be wrong?
Old Jan 8, 2009 | 06:29 PM
bangingd's Avatar
I recall hearing about EGR valves sticking on the 6.0. Might help. Might want to also shoot an email or PM to Bill over at PHP. He is has quite a bit of PSD experience and might be able to give a couple of suggestions.
Good Luck
Old Jan 8, 2009 | 07:47 PM
Labnerd's Avatar
Without codes you're just guessing. I would suspect low fuel pressure. Per Bulletin #19728 for YM 2005, low fuel pressure can be caused by separation of the fuel tank liner. Sometimes it runs and sometimes it won't. But low pressure is what it sounds like. Pull the codes and then you'll know for sure.
Old Jan 8, 2009 | 08:16 PM
Paralyzer's Avatar
if its starts cold and dies when warm its almost certainly a high pressure oil leak. the 6.0 uses HUIE fuel injection which uses high pressure oil to actuate the injectors. if thre is a leak of high pressure oil it does exactly what u are describing and you wont even see the leak as most likely it is internal(pump fitting, injector, branch tube, ect....)
but to be absolutly sure bring it to the local dealer. do not trust any other "mechanics" with a powerstroke as most dont have a clue....or the ability to properly diag and repair.
Old Jan 8, 2009 | 10:34 PM
Raptor05121's Avatar
The first time I opened the hood to our F-450 PSD Ambulance, I almost dropped a brick. Friggin mechanics nightmare
