Door unlocking programing question
Old Jan 1, 2009 | 01:18 PM
Midnightrider's Avatar
I have had by SuperCrew for about 3 months now and was just wondering if there is any way to program the pickup so that all the doors unlock when you push the unlock button the first time? Also if there is a way to get all the doors programmed to unlock when the drivers door is opened? I have looked though the owners manual, and there doesn’t seem to be any mention of something like this, unless I missed it.
Old Jan 1, 2009 | 01:27 PM
re you talking about the using the key fob or are you talking about the key pad on the door?
Old Jan 1, 2009 | 01:47 PM
Tumba's Avatar
There probably are different configuration programs available, but they like to keep those under wraps.
My 97 and 98, you turn the ignition on and off 5 times leaving it in the on position. The door locks will lock and unlock, you then press the lock button on the key fob and they will lock and unlock again, you then turn the key off ,it will then lock unlock again.
With yours there is also a combination with the brake peddle, and maybe cruise button. Someone told me once, but I can't remember the exact combination.
Old Jan 1, 2009 | 03:06 PM
I was talking about the key fob. I found the section in the manual for the key pad. Thanks.
Old Jan 1, 2009 | 03:26 PM
All I have ever heard of is, one click for the driver's door, two for all doors.
Old Jan 1, 2009 | 07:01 PM
chiefFX4's Avatar
its a built in safety feature, i think. just wondering, why do you want to change it? is it really that bad pushing the button twice?
Old Jan 1, 2009 | 09:11 PM
Tumba's Avatar
I decided to look that up, those things I mention about the brake and cruise turned out to be on a Dodge I have.
It stopped the doors from locking when put in drive.
Old Jan 1, 2009 | 09:17 PM
Ive never heard of reprogram available for what you want.
Old Jan 2, 2009 | 10:30 AM
Ya, I didn't know if this was a possibility. The jeep I had before was able to be programmed this way, and it is not that hard push the button twice. Mostly it is annoying when exiting the vehicle all the doors don't unlock, and you try to open the back door to get the kids out.
Old Jan 2, 2009 | 11:42 AM
well the door unlock button the door should unlock all the doors on the first press.
