Configuration Advice!
Old Dec 30, 2008 | 05:34 PM
  #31
If you get the 6 speed auto, axle ratio won't make much difference - 1st is a stump puller and 6th is a super overdrive. However, definitely get rear LSD. Stock tires are fine, as I said in my previous post, you should get a set of crap wheels and studded snows anyway.
Old Dec 30, 2008 | 05:53 PM
  #32
Turbo77's Avatar
Originally Posted by dsq3973
SuperCrew
5.4 V8
FX4 or above trim package
4.10 rear end
Load range D or better tires and not the P rated craptastic tires.
Heavy towing package
5-1/2ft bed
Agreed.
My SCrew has worked perfectly as a family hauler / pellet hauler / general dd. Awesome truck.
Where ya movin to?
Old Dec 30, 2008 | 06:05 PM
  #33
last5oh_302's Avatar
Originally Posted by DriverBill
Thanks for your very informative reply.
I am especially interested in your pointing to the proven reliability of the 4.6 two valve engine--reliability and long-life mean the world to me.
So I'm thinking of getting that engine with the extended cab and I guess a 6.5ft bed.
Do you have any suggestions as to axle ratios, rear ends, wheel size/type (I'm looking for the best function, not the best looks!).
Thanks!
D.B.
Personally, for best all around function, I wouldn't go any steeper than 3.73 gears. I like to be able to cruise on the highway at the same rate of speed as traffic and I don't like reving the bag off my engine. The 4.6 is lacking in power compared to the 5.4. If you're okay with that then it is a reliable engine. The 5.4 is reliable as well, but does have a worse track record, but mainly in the 04 and earlier 05 F150's.
Old Dec 31, 2008 | 04:52 PM
  #34
DriverBill's Avatar
Originally Posted by Turbo77
Agreed.
Where ya movin to?
Alaska, Maine, or New Hapshire
Everyplace else is too warm, too crowded, or lacks an ocean.
Old Dec 31, 2008 | 04:55 PM
  #35
DriverBill's Avatar
Originally Posted by brocious03
The f 150 is going to be just fine for what your looking for. I just came from living in the rocky mountains (Montana) and I have been in some serious stuff. Feet of snow, narrow roads, dirt roads composed of boulders not gravel at 9000ft, ditches, drop offs, steep inclines, -40 degree temps. Never been stranded, stuck, or had anything major go wrong that I did not have an advanced warning of (IWE solenoid). Just a XLT with no skid plates and no damage done and yes I've hit boulders in some bad places. And this was with my General Americraps with 33,000 miles on them before my 33" Toyo M/T's. Plus it will be fine for residential plowing with a small plow, not the big commercial 8+ footers that are very heavy. And I'm sure the boat your getting is not a yacht so it is going to tow it just fine. Good Luck, hope you figure it out.
Thanks for your advice.
Based on your Montana experience, would a Ford Ranger be out of the question for that kind of environment, or must it be the bigger F150?
Old Dec 31, 2008 | 04:59 PM
  #36
DriverBill's Avatar
Is axle ratio the same as rear end ratio?
Many people here advised I get a 4.10 rear end.
Do you think with a 6 speed transmission, a 4.10 rear end isn't necessary?
Thanks.
Old Dec 31, 2008 | 05:12 PM
  #37
Zaairman's Avatar
If you want to do any plowing I wouldn't recommend a Ranger.
Thanks.
I think it'd be easier to find a truck with 3.73s. But either way, gear ratio won't affect you too much, especially since you won't be doing much towing or hauling.
Old Dec 31, 2008 | 05:55 PM
  #38
DriverBill's Avatar
Let's skip the plowing and skip the towing.
Would a Ranger get me around OK in a place like Montana in the winter?
Old Dec 31, 2008 | 05:59 PM
  #39
referee54's Avatar
I would still look at the 150. More power, more ability to haul stuff, and genereally, safer (at least I think.) It would also give you more ground clearance in the snow.
I would get a 6 1/2 foot bed though, as you can haul more stuff with it. I have a LS 3.73 and it has served me well.
Tim C.
Old Dec 31, 2008 | 06:11 PM
  #40
Sure it would. So would an Escape or Sport Trac. If you're not stuck on Ford you could also consider a Colorado/Canyon, Nissan Frontier, or Toyota Tacoma.
Old Jan 3, 2009 | 12:44 AM
  #41
Foe's Avatar
Foe
Originally Posted by OGTerror
[I]There-for we should help an American company Ford that is by buying their products and helping in this tough economic times. This is the time when we should stick together and help each other now that we can. Buying foreign product will only dig a deeper and deeper hole in our economic down turn.
I was standing on my chair and clapping after I read this. Excellent post!
Old Jan 4, 2009 | 01:52 PM
  #42
The SFE package comes with a 4.6 3v, 6 speed auto, and a 3.15 axle. 1st gear is a stump puller so it works just fine. For what you want to do with this truck, the ratio is not that important.
Old Jan 5, 2009 | 01:46 PM
  #43
DriverBill's Avatar
Thanks.
One more question: For light, occassional towing (e.g., Uhaul trailer or SMALL boat), and for just driving around, would a Ford Ranger be good enough in the northern winters, wet muddy springs, and over bad roads?
Old Jan 5, 2009 | 01:48 PM
  #44
Zaairman's Avatar
Thanks.
Yes, it would be fine. My brother's 4 banger 5 speed Ranger pulls my 16' boat ok. It's not a speed demon, but it does get the job done. Not quite as well as my Powerstroke, but you get the idea...
Old Jan 5, 2009 | 04:45 PM
  #45
Norm's Avatar
I live in New Hampshire. I do not have 4 wheel drive or a block heater and I do just fine. I have a camp in Maine on a dirt road and tow an 18 foot boat there as well.
