welder
Old Aug 10, 2008 | 03:09 PM
Camarothatcould's Avatar
Originally Posted by keith97xlt
i got 2 rear studs busted off flush with the manifold so..after i remove it ill have what... 1/2 inch to play with. im just worried about breaking off the rest if them in the head. i was thinking if i just cut off the rest with cut off wheel flush with the manifold ill be able to slide it right off. ive heard about those stud removal tools. ive never used one before.
I JUST did my passenger manifold gaskets last week. I didnt have to weld a thing, and my studs that were broken, were broken 1/4 inch into the head. drill and tap and easy-out. Rest of the intact studs I used vise-grips and got em out just fine
Old Aug 10, 2008 | 03:15 PM
keith97xlt's Avatar
ok i got a 250 5.4 how did u get the 2 lower ones out?? motor mount is right there.
Old Aug 10, 2008 | 03:17 PM
I jacked the engine up and undid the 3 bolts on the mount plate on the block. jacked the engine up more, and snuck my drill in.
this is a 98 expy 4six though
Old Aug 10, 2008 | 03:19 PM
this is the one exhaust stud trapped by the motor mount
my broken off ones were the top left corner on cylinder 4 and the lower right corner on cylinder 1
Old Aug 10, 2008 | 04:12 PM
Tumba's Avatar
And always give the penetrating oil time to do ite thing.
Old Aug 10, 2008 | 04:23 PM
keith97xlt's Avatar
o yea i plan on soaking those babys in pb blaster overnight.
Old Aug 10, 2008 | 04:25 PM
get ahold of me if you get stuck on something
Old Aug 10, 2008 | 04:37 PM
keith97xlt's Avatar
ok cool. those 2 pain in the A$$ studs are still there so i hope i can get a socket on there. i got those sears bolt out sockets.
Old Aug 10, 2008 | 04:40 PM
just dont go crooked while torqueing them out, thats how they break. Stay as straight as possible. Dont cancel out Vise Grips with either, without em, I wouldnt have gotten my existing studs out
Old Aug 10, 2008 | 05:10 PM
keith97xlt's Avatar
ok.i probably wont get to it til next weekend cause of work so.. i have time to get all my tools together. if you think of anymore tips send them my way.
Old Aug 10, 2008 | 05:43 PM
how far along are you? Is the manifold off?
can you get pics of everything?
I took my manifold to the machinist to have it surface decked to make an even sealing surface
I also got my gasket at Advance Auto Parts. They are the nee revised two piece ones. They are awesome!
Old Aug 10, 2008 | 05:50 PM
keith97xlt's Avatar
i havent even started yet lol. i just looked at it real quick and was like" this is gonna be a pain" i figure ill set aside a whole day for this.
Old Aug 10, 2008 | 05:54 PM
Worss comes to worse, you have to drill and tap. This took several hours, and drilling into your aluminum head is not fun, its rather nerve racking. It would be better to zip off your exsisting nuts with an impact gun. Then the studs are less likely to snap off. Most studs snap because of the pressure put on them slowly, if you hit the nuts hard and fast, they'll zip right off
Old Aug 11, 2008 | 05:05 AM
keith97xlt's Avatar
good tip. i replaced driver side in my dakota but..those studs were much easier to get to. the manifold itself was cracked the studs were ok.
