P1405 Code
Old Jul 12, 2008 | 12:36 PM
cletusjermal's Avatar
P1405 Code
I hooked up a code reader to the truck the other day cause the check engine light was on and it came back with a P1405 Code. It said the Differential Pressure feedback sensor upstream hose off or plugged. What is the differential pressure feedback hose?
Old Jul 12, 2008 | 12:40 PM
scott1981's Avatar
EGR valve.
Old Jul 12, 2008 | 12:43 PM
Originally Posted by scott1981
EGR valve.
Do you know where the hose is or where i need to start looking to fix it. I have no idea on what i have to do to fix it.
Old Jul 12, 2008 | 12:48 PM
scott1981's Avatar
https://www.f150online.com/forums/sh...gr+replacement
I havent had any experience doing the swap on a F-150 so here is a pretty good post regarding it
Old Jul 12, 2008 | 12:49 PM
Thanks scott
Old Jul 12, 2008 | 12:52 PM
scott1981's Avatar
Thanks scott
No problem man. One thing I will add is sometimes the EGR isnt bad but 1 of the 2 hoses that goes to it could have come loose or developed a leak. If the hoses check out then it is the EGR and thats only 2 bolts to replace. Im thinking you can get a new one for 80-100 bucks or so.
Old Jul 12, 2008 | 01:07 PM
What is the best way to check for leaks in the hoses. I havent ever had to check for leaks before.
Old Jul 12, 2008 | 01:29 PM
scott1981's Avatar
You can get a hand pump vacuum guage and place it under vac for a couple minutes at a 5 PSI. If the PSI slowly drops you have a leak. They sell kits pretty cheap that come with a variety of hoses and adapters to work on about anything. Sometimes you have to remove these hoses to test them and sometimes you can leave them on. Try to pull a vac and see what happens, if you cant you will probably have to clamp the hose off or take it off to test it. Truth is it is probably the EGR itself as it is a common Ford problem, but would hate to buy a new one then find the hose was loose or had a hole
Here is a picture of a vac similar to the one I use for testing
I think I bought mine for all of 20 bucks at some discount auto parts store
Old Jul 12, 2008 | 02:24 PM
Scruge's Avatar
I just did my 2000 f150 a couple of weeks ago and took some pictures..
http://www.rjpi.com/dpfe2.htm
Old Jul 12, 2008 | 02:31 PM
scott1981's Avatar
Now that is a detailed write up! Thanks for posting
Old Jul 12, 2008 | 11:18 PM
Awesome. Thanks
