Lawn mower engine issue
Old May 23, 2008 | 10:07 PM
Dr. Franko's Avatar
I got this John Deere, that isn't that old, but has not been run in a couple years. I put gas in it but it won't start. I pull the plug and shoot in some starting fluid and put the plug back but no start. I then pull the plug and lay it by the head, to check for spark, and it sparks and also ignites the fluid in the cylinder which shoots a flame. I then put the plug back in but it still won't start. So there is spark and fuel but it doesn't start.
Old May 23, 2008 | 10:12 PM
Quintin's Avatar
Is the fuel cap on the tank, and is it tight? What about the air filter, what's it look like? Stopped up? Clean?
Old May 23, 2008 | 10:25 PM
Dr. Franko's Avatar
Cap is on tight. Only took a quick look at the filter, maybe I should pull it off and try to start it.
Old May 23, 2008 | 10:28 PM
azmidget91's Avatar
try to clean the carb, pull it off and take the bowl off the bottom and clean it with carb cleaner
Old May 23, 2008 | 11:33 PM
Gipraw's Avatar
there is your answer. take the carb apart, clean it, put it back together, it will run fine.
Old May 24, 2008 | 12:10 AM
Dr. Franko's Avatar
Well I guess as soon as I get some time it's carb cleaning.
Old May 24, 2008 | 12:36 AM
Shinesintx's Avatar
Carb? Waterbong?
Old May 24, 2008 | 01:38 AM
I have an issue with mine too. It's a push mower.
Old May 24, 2008 | 09:14 AM
What type engine?
Old May 24, 2008 | 12:31 PM
What type engine?
The issue I have with my push mower has nothing to do with the engine. The engine runs like a top. The issue I have with my push mower is the fact that I have to push it once a week.
Old May 24, 2008 | 01:55 PM
Ranger7489's Avatar
thank god i live in an apartment
Old May 24, 2008 | 02:17 PM
Gipraw's Avatar
thank God I live in Texas.
Old May 24, 2008 | 02:22 PM
Old May 24, 2008 | 02:38 PM
Make it self propelled.
Old May 24, 2008 | 02:41 PM
I am, mostly. That's all I've got!
