lawn tractor issue
Old May 14, 2008 | 12:08 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
lawn tractor issue
I have a SLT 1554 cub cadet with a 27hp engine. when running it will not idle properly, it just revs up and down. When blades are engaged it has no problem runs fine with a load on. As soon as i disengage the blades it begins to rev up and down and seems to be missing at times. Any ideas?????
Old May 14, 2008 | 12:49 PM
jward's Avatar
Spark plug fouled, faulty, or gap too wide.
Dirty air cleaner.
Choke activated.
Old May 14, 2008 | 01:27 PM
I've had this happen on my GT1554. We've got the same engines...
It was a dirty fuel filter that was causing my issue.
Here's mine...
Old May 14, 2008 | 01:51 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
I won't embarrass you by asking how much you paid for it because
it looks to me like you're peeling out of an empty Home Depot parking lot, in too much of a hurry to shove it in all the way.
With your head down so low we can't even id you.
Old May 15, 2008 | 12:06 PM
Okay installed new gas filter yesterday, no difference??? come on someone knows....... I figure something is plugged up inside the carb any one else care to take a stab at it.
Old May 15, 2008 | 12:34 PM
jward's Avatar
OK then, let me put it to you like this.
Spark plug fouled, faulty, or gap too wide?
Dirty air cleaner?
Choke activated?
Old May 15, 2008 | 01:50 PM
Raoul's Avatar
25 Year Member
Clean the carburetor, take it off and clean it good.
Old May 15, 2008 | 02:10 PM
http://www.kohlerengines.com/common/.../tp_2450_b.pdf
That is the service manual to that engine.
Look on page 40...
Old May 15, 2008 | 02:14 PM
beckerjs's Avatar
its starving for gas, check tank vent, adjust idle mixture, check air filter as mentioned, possible fuel pump but doubtful. It runs better with the blades engauged because the govenor is regulating the speed of the engine.
Old May 15, 2008 | 02:19 PM
Raoul's Avatar
25 Year Member
Look on page 40...
Good link.
look at page 5.7
Old May 16, 2008 | 08:56 AM
I love you guys come here give jimmy big huggy!!!!!!, Thanks i will try the carb clean out. Air filter is new as are the plugs, choke fine ( i like you)
Old May 16, 2008 | 09:40 AM
srfd44's Avatar
use Seafoam in the gas, that will clean it out
Old May 16, 2008 | 02:39 PM
Originally Posted by buckdropper
...any one else care to take a stab at it.
Excessive down time attributable to 11-months of snow per year in your area.....
Old May 16, 2008 | 07:23 PM
Tumba's Avatar
The old style sidedraft are what all the lawnmowers I've seen have. It is usually dirty mixture jets. Sometimes it is pulses from a worn out fuel pump{not very often} I didn't notice in the above post but check the pulse line to the fuel pump for leaks.
Turning the mixture screws don't help most of the time. Look it up onlime I've found a few lawnmower forums. I even found one site the had links to complete breakdown of engines.
Clean the carb and count the number of turns on the mixture screws, and put them back to the original settings. What ever you do Don't change the float level. It is usually a very small spring that holds everything in place.
Also the float could be leaking. {does it ever sound lean on the top end or does it ever kick back and die}
When minedoes this i sometimes take the screws out , then give it low presure bursts of air.
Old May 16, 2008 | 07:54 PM
Agent47's Avatar
Get rid of it & buy a Deere!!
