Compressing Brake Piston
Old May 14, 2008 | 09:01 AM
Originally Posted by Camarothatcould
If installing a new caliper, it owul dbe best to go ahead and bleed everything else. Remember, start bleeding farthest from ressy than work closer
Yep, which is the rear right, then the rear left, then the front right, then the front left.
Luckily I got a lot of brake fluid, so I've got plenty to do the whole system.
My friend is really bargaining out on this... I wasn't planning on flushing the brake system.
Finally, say, with all the parts and labor... how much would this type of job cost him at a dealer or a really good shop?
He spent:
4 rotors: $260
4 brakes: $120
1 Caliper: $130
4 slide pins: $35
2 bolts: $5
Total: $550
My time:
Jacking the vehicle up on jackstands, taking the wheels off, removing rusted brake bolts, snapping 4 slide pin bolts, snapping 2 caliper mounting bolts, needed to machine out the stuck bolts (I did it) total of about 1 hour, reinstalling brakes and mounting hardware, bleeding brake system, and putting wheels back on, then do a test drive. So far I'm up to 7 hours on this project... I plan on having 2 more hours on it, if nothing else goes wrong.
He also wants me to change his plugs and do an oil change.
So how much should I charge him?
I know this work combined would nearly cost him over $1000... probably of that about $400 in labor if done in a regular shop... maybe more. Anyone know?
Old May 14, 2008 | 12:38 PM
FX4ME2's Avatar
If he is a good friend, charge him $25 a wheel for the brake job, and $25 for the tune up if it's real easy.
Old May 14, 2008 | 01:25 PM
Oh the tune up will be easy...
I think $25 a side sounds good... plus the $25 for the tuneup...
$125 isn't too much to ask...
Old May 14, 2008 | 10:14 PM
Larry227's Avatar
If it was in our shop he would be paying 90.00 an hour. I don't think he should complain about 125.00.
