Old Nov 21, 2011 | 06:13 PM
  #69886
I can beat that if I have a 10 mph tail wind and set the cruise at 65.
dont get beat by a lil' ol' 4.6 now
Old Nov 21, 2011 | 06:16 PM
  #69887
Mine's carrying a lot more weight!
Old Nov 21, 2011 | 09:12 PM
  #69888
dsq3973's Avatar
Originally Posted by Toyz
What do you have going on, carb issues? Ive torn a few apart. Give me a quic update.. What carb is it? Oh wait... I'm only familiar with jap carbs. Mikuni, keihin, etc. But they all have the same concept. Slide, needle valve, main jet, pilot jet, float, you get it. Is it choking out when you start it? Dumping fuel from the overflow? What air system does it use? Have you pulled the plugs to see if it is rich or lean..
The carb is for a Kohler K301 12hp in a 1978 John Deere 312 with unknown hours on the engine and everything looks to be original.
I went through the carb this summer while I was rebuilding the rest of the tractor and replaced the throttle shaft and plate, gaskets, float seat cup and needle valve. It's leaking around the needle valve and just flooding the intake from what I can see. I also rebuilt the govenor linkage because the old one was plain worn out and I just ordered the rest of the parts to replace the rest of the govenor linkage. It's running extremely rich and when I try and lean it out I can't seem to find a happy medium even with John Deere's setting from the service manual.
Here is the old one.
Here is the new one.
Old Nov 21, 2011 | 09:51 PM
  #69889
Toyz's Avatar
I'm going to see if I can find a diagram of it. Sounds like what everyone else has said though, float adjustment or needle valve not seating properly. If you dont have an adjustable air gauge I normally just blow through the fuel line when checking whether it has seated. The seams on the float should be level with the bowl when seated. Is the air filter soaked in fuel? Had a chance to check the timing or valve clearance? If the timing is off or the valves are not seating, it can blow fuel back through the carb. And would run like crap
Old Nov 21, 2011 | 10:20 PM
  #69890
dsq3973's Avatar
I have done everything short of taking it to a carb shop, the fuel shut off has no unusual wear and I have even adjusted the float so it shuts the fuel off sooner and it still runs extremely rich. When the tractor was barley running I took my LED Mag Light and was watching the pattern and where the needle valve comes up into the venturi I could see the spray from the high speed jet but there seems to be fuel leaking from around the bottom of the high speed jet and all the parts are accounted for from what I can see.
Here are some diagrams from the JD parts catalog.
http://jdpc.deere.com/jdpc/servlet/c...ageServlet_Alt
Old Nov 21, 2011 | 10:31 PM
  #69891
Alex_4.2L's Avatar
My girlfriend gets a brand new shiney car and all of a sudden it seems there is a nice F150 for sale every where I look. Drivin me nuts
Old Nov 21, 2011 | 11:15 PM
  #69892
ian51279's Avatar
Resist the temptation! I'm trying since I finally got mine paid off.
Old Nov 21, 2011 | 11:32 PM
  #69893
https://www.f150online.com/forums/19...ml#post4723256
Old Nov 21, 2011 | 11:56 PM
  #69894
Toyz's Avatar
Does it have a fixed main jet or adjustable? I'm reading it had 2 carb options, either kohler or walbro. Each has it's own settings for lean/rich mixtures, idle etc..
Not sure if this is the manual you have but it has some basic tuning information for your carb. Page 11-13
I'm wondering if you have the adjustable main jet, if it is not sitting all the way into where it goes or is not adjusted. I duno.
http://www.kohlerengines.com/onlinec...1346_c_all.pdf
Old Nov 22, 2011 | 03:06 AM
  #69895
jbrew's Avatar
Links no worky.
That carbs so old, I'd have to see it apart. Or a diagram, -you probably did all that. Probably not a Walbro, I suspect a Kohler or Lauson Power Carb.
Mikuni, Keihin ? Who said that ? -It's not a dirt bike Toyz
Just get a new one Dave, -get a Holly double pumper
Old Nov 22, 2011 | 06:33 AM
  #69896
06F150STX's Avatar
Old Nov 22, 2011 | 07:59 AM
  #69897
Old Nov 22, 2011 | 08:05 AM
  #69898
jbrew's Avatar
As old is that carb is Dave and looking at your pic, I'm pretty sure that's ban old Onan. They had that idle/fuel screw right on top like that. I had one on a backup generator for the Freight Liner.
It might not be, it's the only straight up and down set screw type that I've seen in the past.
Anyway, -were you able to find an EXACT kit for that particular model. That would be tough.
Which carb did you order ?
Old Nov 22, 2011 | 08:06 AM
  #69899
jbrew's Avatar
Morning Milk weeds
Old Nov 22, 2011 | 08:15 AM
  #69900
dsq3973's Avatar
It's a Kohler, the high speed jet is on top and it's adjustable. I have the Deere service manual for the tractor and they have the adjustment for both carbs. I just need the damn thing to run and quit sucking money out of my savings account.
