Not sure about the question. Most homes being built now are on a concrete slab. The walls are wood frame with sheetrock on the inside and a fiber board insulation on the outside of the frame, then an outer brick wall. There are still a few homes in certain areas that are pier and beam. A lot of the commercial buildings are tilt concrete walls.
That's right, you guys don't do basements huh? So the slab is sitting on what? Just pilings and grade beams? Or is there some sort of shallow footer/spread footer with small wall?
No basements. Generally, a mix of sand and soil is built up and leveled about 12 inches or so above ground level. The plumbing is laid in trenches with sand then spread over it. Forms are built around the perimeter. Then concrete is poured. If the future home owner pays for it, piers are drilled and poured as part of the slab.
yes, I think you have it. Good ones will not crack much, but those that are done by shady contractors tend to crack. Also depends on the soil composition and how much shifting is going on.
Check this out. I'm estimating a 4 unit townhouse right now on Lake Erie, about 7000 sq ft, slab construction on a 4' x 8" wall on 3' spread footer and it's going to take 210 tons of re-bar!!!! That my friend is a lot of steel for a unit this size.
Yeah, re-bar not installed correctly or not enough steel will compromise the integrity especially when climatic conditions play a role which they always do sooner or later.
I have a hard fast rule if I cant stand the smell I wont eat it.
it goes for food, and something else I wont mention 'cause I dont wanna get a bad boy note
got done working in my garage, made a badass shelf in my garage that straddles my truck, ill take pics later this week once i get the garage all cleaned up.
Im tired, gonna go hit the shower in a minute, then crash
