Old May 31, 2011 | 11:28 PM
  #60991
Go HEAT!
Old May 31, 2011 | 11:29 PM
  #60992
Originally Posted by ian51279
damnyouautocorrect.com? Some of them had me in tears.
Old Jun 1, 2011 | 12:21 AM
  #60993
Originally Posted by 88racing
No difference than if they're turned off....
you only mod rear 02s, which only monitor cat efficiency, the fronts monitor fuel trims. you leave those alone. Not sure what you mean you can't see if you have a problem.... Maybe you didnt understand how the 02s are setup
My point exactly Pat.
If the front 02's fail, you have no way of knowing it seems if the rears are shut off. If you are running rich, exhuast leak, etc then there would be no P0420/P0430, correct? Or say in Will's case, what if he had an exhaust leak and had the rear sensors shut off? He wouldn't really know, right? I get how they work, but it seems to me they are there for a reason and should be left alone so you can make sure your exhuast is healthy
Old Jun 1, 2011 | 12:27 AM
  #60994
bucky919's Avatar
Got everything out of the house, im going to stay on the deck with my favorite set of water wings and trusty Bud Light and watch them build the dike behind my house hopefully they get it done in time...
Old Jun 1, 2011 | 12:44 AM
  #60995
If the front 02s fail then you get a P0053, P0059, PO131, PO132, PO133, PO134, PO135, PO150, PO151, PO152, PO153, PO154, PO155 as well as your normal PO170, PO171, PO172, PO173, PO174, PO175
IDK what is so complicated about it, again the fronts are the main sensors, if they fail or get bad readings they throw codes, and can throw lots of codes. Rears only monitor cat efficiency, thats all.....
Old Jun 1, 2011 | 05:51 AM
  #60996
I need a nap. :o
Old Jun 1, 2011 | 06:24 AM
  #60997
06F150STX's Avatar
^^Me too.
Old Jun 1, 2011 | 07:41 AM
  #60998
dsq3973's Avatar
Morning. I think I got about 3 hours of sleep last night this is going to be a very long day.
Old Jun 1, 2011 | 08:37 AM
  #60999
Old Jun 1, 2011 | 11:29 AM
  #61000
What is the deal with the clock? lunch is still an hour away.
Old Jun 1, 2011 | 11:33 AM
  #61001
dsq3973's Avatar
I know it's been dragging this morning for some reason. I think I am going to take an early linch and run some errands.
Old Jun 1, 2011 | 11:35 AM
  #61002
Good grief!
Old Jun 1, 2011 | 11:49 AM
  #61003
Linch in 10
Old Jun 1, 2011 | 11:51 AM
  #61004
harleydude78's Avatar
i'm starving
Old Jun 1, 2011 | 12:29 PM
  #61005
dsq3973's Avatar
Good grief!
You and Pam were great teachers.......
