Moles!!! HELP !!
Old Mar 21, 2008 | 02:48 PM
wrobo23's Avatar
Speaking of this is there some sort "plunging" mole trap that uses shotgun shells as well? I swear that there was a farmer when I was younger that had one that when the trap was "sprung" it blasted shot into the ground as well. Maybe it was b.s.... I always wondered about that.
Old Mar 21, 2008 | 08:40 PM
RightTurn's Avatar
Originally Posted by JBMX928
juicy fruit.
yup. we used bubbalicious though. worked great!
Old Mar 21, 2008 | 08:55 PM
06 SANDSTONE's Avatar
Originally Posted by Enoch
read the squirrel thread. Make a mole launcher!
if i catch one, I'll shoot it thru my potato gun .
Old Mar 22, 2008 | 12:15 AM
Shinesintx's Avatar
Not only is it effective...but entertaining also.
OK, so I will bite...Whats the deal with Juicy Fruit and moles? I am from Texas, and have only seen moles in books and TV...
Old Mar 22, 2008 | 12:20 AM
mSaLL150's Avatar
hmm, i'll give same advice here as i did for squirrels...
Originally Posted by mSaLL150
12 guage, case of shells, 18 pack of brews, and a lawn chair. Have a super sweet day.
Old Mar 22, 2008 | 12:33 AM
bpciprez's Avatar
Originally Posted by cvc14
So you still need to find the active mole tunnel and put this Tomcat down the hole? I dont remember the stuff i tried last summer and it so did not work.
I did get one of them with a post hole digger bc the stupid thing dug into the hole I was digger.
I am buying a .22 for the ground hogs but it would be to hard to shoot the mole.
Correct. If you don't have an active run, you're just putting a really expensive fake worm inthe ground. To find out which runs are active, take a dowel rod or piece of rebar and poke a hole in the tunne. Be sure to mark the hole with a can of marking paint so you remember where they are. Also,the holes should be every 5-10 feet. Mole will actually repair holes in their tunnels, so you can come back a couple of days later to check your holes and if they have been "plugged" you can put a 1/2 worm down the hole. That's a pretty quick overview, but you should repeat the process every couple of weeks and watch for areas of new activity.
Old Mar 22, 2008 | 06:35 AM
Tumba's Avatar
wats up with the juicy fruit
X2
Old Mar 22, 2008 | 10:43 AM
bpciprez's Avatar
X2
one of the hundreds of "home remedies" that people swear work. Let's see.... putting a hose in the tunnels, pouring gas and lighting it, sitting with a six pack and a gun, hair, gum, treating for grubs, and so on.
Old Mar 22, 2008 | 10:48 AM
RightTurn's Avatar
X2
Stick a couple pieces down one of thier holes. They try to eat it, and end up either choking on it or plugging themselves us so bad they die. thats what i have heard, and it did work for us, so i dont know what actually happens to em, i just know it worked.
Old Mar 22, 2008 | 11:52 AM
4x4whiteSTX's Avatar
I never thought about gum but thats actually a good idea, i always used the traps that stick in the ground and pinch the mole when they walk under it. I never had a very high sucess rate with those, usually i'd only get the mole after about 4 tries. But after i got it i was amazed that no new tracks appeared in the lawn, its amazing how much damage one mole can do.
Old Mar 22, 2008 | 11:57 AM
Tumba's Avatar
I seem to be having trouble with armadillos. I haven't set up with the old mossberg yet.. Sould I use field loads to run 'em off. or plug them good with a duck or turkey load?
Old Mar 22, 2008 | 01:59 PM
just2tow's Avatar
3 1/2 turkey load should work. can you eat those things
Old Mar 22, 2008 | 08:29 PM
Tumba's Avatar
I wouldn't want to skin one!
Old Mar 22, 2008 | 08:34 PM
just2tow's Avatar
Armadillo soup?
Old Mar 22, 2008 | 11:39 PM
OrdnanceCorps's Avatar
get a cheap 22 with dog or rat shot... or a 12 ga with bean bags .. lmao
