V6 with extended cab?
Old Dec 31, 2007 | 12:14 AM
gsxrida1980's Avatar
I'm wanting to get a used F-150 V6 for fuel efficiency purposes. I also want the second row of seats but can't seem to find one. Am I spinning my wheels? Does Ford only offer the extended cab in a V8? Thanks in advance for the help. Peter
Old Dec 31, 2007 | 12:25 AM
keith_bennett's Avatar
They make v6 extended cab
Old Dec 31, 2007 | 12:33 AM
Bartak1's Avatar
Usually only see the v6 in the reg. cabs, but they do make them in the ext. cab form....keep looking
Old Dec 31, 2007 | 12:45 AM
thanks Bar. I've looked around on fleabay and on other sites with no luck. doesn't look like Ford even made the V6 after 2004
Old Dec 31, 2007 | 12:59 AM
They still make V6 F-150's. However, I believe the last year the V6 was offered in an extended cab was 2003 and *maybe* the 2004 Heritage (OBS). I know for a fact that there are 2002 V6 extended cabs, I just Googled and found one on Craigslist.
Old Dec 31, 2007 | 02:15 AM
silversvt04's Avatar
I have had two , a 97 and a 98. The top half of the bottem seat folds foreward creating a flat surface that is flat and works well for level storage.
It has a third door that is on the curb side.
Both trucks were the v-6 2 wheel drive posi axles.
In some the rear side windows push out. Nice trucks.
Old Dec 31, 2007 | 02:23 AM
jiggle's Avatar
Not with the V6, you're not
Old Dec 31, 2007 | 02:42 AM
Yes you can...
Old Dec 31, 2007 | 07:16 AM
02SuperCrew4X's Avatar
If you want a V6 and a Supercab, you have to buy a 97-03 or an 04 Heritage. The current body style of F-150 is too freaking heavy for a 6 cylinder, thus Ford doesn't produce it. I've heard you can custom order one with a V6 and Supercab but who knows what truth there is in that.
Old Dec 31, 2007 | 08:31 AM
Quintin's Avatar
For what it's worth, the V6 probably won't get any better fuel mileage than a V8 will. The 6 has to work harder than the 8 to carry the truck down the road, more work = the same or more fuel used.
Old Dec 31, 2007 | 10:44 AM
ranger81's Avatar
Yes you can...
Manual's love for the v6 knows no bounds....
Old Dec 31, 2007 | 10:47 AM
JBMX928's Avatar
Graphics Contributor
looks like ford finally has an automatic v6 too. Is 08 the first year for this?
Old Dec 31, 2007 | 01:30 PM
My buddies 2002 ext cab v6 is automatic.
Old Dec 31, 2007 | 03:41 PM
Octane36's Avatar
You arent going to gain any fuel efficiency with a V6. That V6 has to work harder than do the V8s, so even though its a smaller engine, it doesnt get any better gas milage.
Do yourself a favor, get one with a V8. You will appreciate having the power available and as long as you dont drive like a maniac all the time, you can get the same gas milage a V6 gets.
Old Dec 31, 2007 | 04:08 PM
JBMX928's Avatar
if you buy the v6 f150 and use it the same way you would a midsize sedan then it will get better mileage cuz youre not using it for work.
