Optima battery stinks in the cold
Old Dec 15, 2007 | 10:41 PM
ThumperMX113's Avatar
Hmm .. I've got a red top in my 65 Mustang and it only gets started every week. Cranks no problem.
Old Dec 15, 2007 | 10:54 PM
BLUE20004X4's Avatar
we'll see come spring what my battery will do, I am pumped to finish the car and probably won't give it time to die out anyways. Since it will have a bit of a system in it, I was advised a yellow top, sounds good to me.
Old Dec 15, 2007 | 11:07 PM
Impact9's Avatar
Originally Posted by BLUE20004X4
Ordinarily, red tops fire up fine. Let them sit even the least little bit, they're dead. A little cold, dead. I don't know why. My bro has or had one in his daily driver, no problems unless it sits for a week. Same on his stang, since it gets started every week, each time it's like on the verge of drained. I'm planning on a yellow top in my old car to see wtf is all the hype about.
That's what mine does. If I let it sit 2 days it goes dead with the cold weather it's dead in no time. I've check for parasitic drains with no luck in the past with this problem.
A year or so back I had a problem with my headrest monitors draining the battery since I didn't wire the switched power to a switched source. They wasn't on all the time but they still pulled too much juice and would drain the battery over night. Then this started happening now the weather went bad.
Right now I'm thinking maybe I've taxed the battery too much and it's not keeping a charge. I mean, if I blast the stereo and hit the offroad lights I can see serious drain happening. I do use the offroad lights a lot too. I wonder if these batteries have a memory then?
Old Dec 15, 2007 | 11:11 PM
I'd really try to get a Yellowtop to see if that fixes your problem. Otherwise you might need to start using two batteries.
Old Dec 15, 2007 | 11:21 PM
Impact9's Avatar
Yea then I'd be like Styx
Old Dec 15, 2007 | 11:26 PM
styxnpicks's Avatar
Old Dec 15, 2007 | 11:30 PM
Impact9's Avatar
Say styx what happen to your modded battery box pics?
Old Dec 15, 2007 | 11:50 PM
styxnpicks's Avatar
you mean this one?
Old Dec 15, 2007 | 11:53 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
I know it gets cold in Ohio, but does it really get that cold?
Old Dec 16, 2007 | 12:58 AM
Gray Ghost's Avatar
Man, impact... you honestly have the baddest f-150 i've ever seen... show trucks are nice and all but your truck is just an original bad *** truck... your truck just says "GET THE **** OUT MY WAY" all over it... i hope to get my truck to look like that one day... slowly but surly
Old Dec 16, 2007 | 01:09 AM
Zaairman's Avatar
My guess is that he ran that Red Top down really low once. Run a Red Top downonce, and its toast.
Old Dec 16, 2007 | 01:11 AM
I like my Motorcraft batteries... but I've heard nothing but great comments about the Yellow Tops.
Old Dec 16, 2007 | 01:18 AM
Grubrunner's Avatar
Originally Posted by ian51279
I use Die Hard.
X2
Old Dec 16, 2007 | 01:37 AM
wild-mtn-rose's Avatar
Not sure what color the one is in my husband's Bronco but it fires every time!
Old Dec 16, 2007 | 01:53 AM
PSS-Mag's Avatar
No I meant styxnpicks, with the dual yellow tops in parallel. Doe's he need that many CCA? I'm assuming if your going that far then you'd have at least 1800 cca each, otherwise you'd be wasting your time and money when he could get it all in one battery. So presumably he's be putting out 3600 Cold Cranking Amps. on a gas engine or one helluva sound system......
