Need some IT Help
Old Oct 3, 2007 | 01:16 PM
jdoggfx4's Avatar
Need some IT Help
I working on a small network with 10 PC's on it. They are in a workgroup. Latley they are having problems accessing a mapped drive on the server. (ie it is slow to respond)
They are running a mix of server 2003 and server 2000.
Any idea what could casue this?
It does not happen everytime the try to access the drive.
Justin
Old Oct 3, 2007 | 01:55 PM
TeckBargins's Avatar
Are you using a switch or hub?
Is it just after bootup/login?
Old Oct 3, 2007 | 02:05 PM
jdoggfx4's Avatar
Using a switch
It usally happens after a couple hours into the work day
Old Oct 3, 2007 | 02:14 PM
how olds the your hardware?
Any chance of problems with wires, running by large electric equipment?
Does it happen to everyone after a certain time or just random?
Old Oct 3, 2007 | 03:06 PM
jdoggfx4's Avatar
The equipment is new (ie within the last 3 months)
It seems to happen at random on different computers throughout the day
Old Oct 3, 2007 | 03:22 PM
are the credentials the same on both machines?
Are you using just 1 general login for server shares?
if they are in a workgroup and not part of a network, are you just using a login script?
Old Oct 3, 2007 | 03:44 PM
jdoggfx4's Avatar
Same user and passwrod for all
One login for all machines
the drives are all mapped at login
Old Oct 3, 2007 | 03:59 PM
crowe10's Avatar
Have you tried running any perfmons on the local server that the shared folder resides on? CPU, disk IO counters, memory, nic? then you can map the timing of the performance to reported complaints. If nothing shows up it would probably be some other bottleneck on the network or possibly some OS patch needed (doesn't sound like it in this case but could be)
Old Oct 4, 2007 | 08:35 AM
jdoggfx4's Avatar
I ran a trace program and everything seems to be in order.
Old Oct 4, 2007 | 04:20 PM
Does any of the servers have a user limit or timeout feature on connection?
