Fixing a Leaky Faucet
Old Sep 27, 2007 | 10:54 AM
rogue1's Avatar
Originally Posted by RockPick
Wow... that was easy.
The nice lady on the other end of the phone line was **EXTREMELY** helpful and has already placed an order for me for the parts. They should be here within the next 3 days -- free of charge.
Thanks again for pointing out the warranty!!
Before you yard it out, try taking the handle off and check the crown shaped nut for tightness (not overtight). Also, grit in the lines will trash your O-rings. Disconnect the lines under the sink after you shut the valves off, and get a bucket and open the valves and blow the lines out. Look in the bucket, and you are likely to have all kinds of grit. Keep cranking the valves open and jazzing the lines until the water in the bucket is clear. Trust me.
I talked to a plummer who did the plumming on a resort addition, and they didn't blow out the lines, and after a year, they had replaced all of the new faucets they just installed.
Old Sep 27, 2007 | 12:04 PM
Zaairman's Avatar
No problem... Scary part is, I'm starting to think more like my father... If it has a warranty, you bet your *** he's gonna milk it for all it's worth.
Old Sep 27, 2007 | 02:58 PM
Bartak1's Avatar
Originally Posted by mkosu04
Why would you put a bucket under it??? Doesn't it have a sink under it?
Touche my freind....touche...
