For the people who have dug wells...
Old Sep 7, 2007 | 04:42 PM
Krohbar's Avatar
What did you pay for a complete well service to your house?? I'm getting number of $11,000 for a 300ft well, pumps, tank, etc...
Old Sep 7, 2007 | 08:00 PM
Photog95's Avatar
That seems like a pretty good price. My sister had hers done a few years ago and it cost her just under $15,000 to go 275 feet. I just had mine redone a couple years ago as well. My pipe was getting bad and my pump locked up. It was about $1,500 for new plastic pipe, pump and wire. My well is 180 feet deep.
Old Sep 7, 2007 | 08:16 PM
We have a 36 ft dug well. It's been serving us for about 15 years now with no problems... just the normal sediment issues.
300 ft for a dug well sounds kind of deep to go with an excavator... do you mean a drilled well?
A dug well is one that is dug using a backhoe then is filled in with a rock bed and has a casing that is then filled in around with dirt.
A drilled well is one that is drilled using a truck that feeds casing into the ground to prevent the drilled wall from collapsing.
Old Sep 7, 2007 | 11:42 PM
last5oh_302's Avatar
Definitely drilled, and the price tags for it seem to correspond. Actually, from what I recall, $11,000 for 300 feet is pretty good.
Old Sep 8, 2007 | 12:16 AM
Photog95's Avatar
Yea...mine's drilled as well. I didn't think anyone actually dug wells anymore. Hell I even have an old (still working) spring house in my back yard but it doesn't get used anymore.
Old Sep 8, 2007 | 06:43 AM
Habibi's Avatar
Around here you pretty much see dug wells on waterfront properties only, and occassional rural.
My drilled well is 180 feet deep as well and 11k sounds like a pretty good price. I know ours was a lot because our house sits on solid limestone, so they had their work cut out for them.
I cringe at the thought of putting a pool in, the blasting is gonna be expensive!
Old Sep 8, 2007 | 10:27 AM
JBMX928's Avatar
Graphics Contributor
damn i didnt think that **** was that expensive...
Old Sep 8, 2007 | 10:52 AM
BalogUK's Avatar
we're at oh 536' deep- 11k is a gooood price
Old Sep 8, 2007 | 12:28 PM
Photog95's Avatar
Damn!!!! You must not even need a water heater. Your luck you aren't pumping magma there.
Old Sep 8, 2007 | 12:49 PM
Photog95's Avatar
They make some pretty fancy above ground pools these days. http://www.poolproducts.com/Empty/ch...oolskdrect.htm
Build a nice deck around it and you are good to go.
Old Sep 8, 2007 | 02:36 PM
Copenhagen848's Avatar
I used to live in a rural area and only had to go down about 100'.....my bill was under $3000 :o
Old Sep 8, 2007 | 04:12 PM
wild-mtn-rose's Avatar
Our well was already on the property when we bought it so I have no idea what the cost was. It's down through 300' of solid granite, so it couldn't have been cheap!! We also have a dug well of undetermined depth. Only use that one for watering one small flower bed because there is no power down there and all we have is a pitcher pump on it.
Old Sep 8, 2007 | 11:06 PM
Krohbar's Avatar
Dug, drilled... same thing...
I just had no clue about the expense in this...
Old Sep 9, 2007 | 10:35 AM
FX4ME2's Avatar
82 ft down and a new pump cost me $4000.00
Old Sep 10, 2007 | 03:07 PM
rcrupper's Avatar
I just had a 308' drilled with tanks and 1 1/2 hp pump and it came to $5900. Your price seems kinda steep to me..
good luck.
rob
