Signature Creation Request
Old Aug 14, 2007 | 11:49 AM
baja150's Avatar
I was going to take about 8-16 pictures of my truck from all different angles. Could anyone make me an animated GIF with the pictures to make it look like the truck is rotating?
Old Aug 14, 2007 | 05:46 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
I can try, but I'm affraid with even 8 pics the file size will be to large or I'll have to reduce the quality unitl it looks nasty. also with ohnly 8 views it might be a little choppy as it turns. But I woudl like to try it and see what I can do.
Be sure to use a tripod so all the pics are the same height... and move the truck not the camera so that you have teh same lighting, also measure to make sure you are the same distance with in 3 "+/- from the truck to the camera and dont move the zoom. Time saving tip: Use a string tied to the tri pod and mark it with tape the distance of the first shot.
ETA:
Start with a broad side, and fill the view wti truck as best as you can. This way every shot will be as full of truck as you can with out getting closer moving back or zomming out. You dont want the camera to move.
