Check this out: What is this? Radiator Issue?
Old May 31, 2007 | 08:53 PM
Msl747's Avatar
Originally Posted by ohboy44
The coolant is green because that's not a 04 and up truck, unless it's a 04Heritage.
Its an '05
Old May 31, 2007 | 09:01 PM
ohboy44's Avatar
Originally Posted by Msl747
Its an '05
A 05 "what" is the question then. Because a 05 F150 doesn't have a cap on the radiator, it has a degas bottle with a pressure cap on it.
Old May 31, 2007 | 09:22 PM
RUSS04's Avatar
[QUOTE=ohboy44]A 05 "what" is the question then. Because a 05 F150 doesn't have a cap on the radiator, it has a degas bottle with a pressure cap on it.[/QUOTEYour Correct It must be a very early model F150 to have a cap on the radiator Its not a 2005
Old May 31, 2007 | 10:35 PM
bri687's Avatar
Originally Posted by BtownFord
I noticed I was using a lot of coolant and decided to check my cap. What does this tell me???
The washer fluid resovor is different then my 06
Old May 31, 2007 | 11:02 PM
Rambo's Avatar
Is it even an F-150? I have an '05 and the coolent resevoir does not look anything like yours.
Old May 31, 2007 | 11:07 PM
Msl747's Avatar
I assumed '05 b/c thats what his profile says, and this is posted in the 04-07 section... Ok, yeah just looked at mine and its completely different... my coolant is gold colored btw...
Old May 31, 2007 | 11:16 PM
Msl747's Avatar
Ok, here: https://www.f150online.com/forums/sh...d.php?t=286894 he says:
Clutch Question
I Just picked up a small pickup truck for my daily driver yesterday. It is a 5 speed with 2.2L 4Cyl.
So I assume this is the truck in question...
Old May 31, 2007 | 11:35 PM
Huitt24's Avatar
looks like corrosion from under the hood which should be fine.
The green anti freeze and the fact the radiator cap is actually on the radiator tells me that this isnt a 05 Truck
Old May 31, 2007 | 11:48 PM
Tylus's Avatar
I don't understand what the question is. Those pics he posted look just fine to me. My 06 should be perfectly clean IMO, but that little bit of corrosion on a 2-3 yr old truck is perfectly fine in my book.
So what is the proper anti-freeze? Seems like the majority have gold/amber colored coolant.
Old Jun 1, 2007 | 08:26 AM
svtenthusiast's Avatar
It's a chevy because it says "Delphi" on the fuse box.
Old Jun 1, 2007 | 11:55 AM
dbhost's Avatar
Nice catch!
Old Jun 1, 2007 | 02:27 PM
Rockpick's Avatar
Moderator &
Delphi is Daimler Chrysler... isn't it? Chevy is AC Delco.
Either way... off to General... it's had a happy life here in the 04+ forum.
-RP-
Old Jun 1, 2007 | 04:28 PM
MitchF150's Avatar
That coolant looks terrible to me..... When was the last time it was changed? If it's been recently, then there is some contamination going on by probably a blown head gasket or something....
It should be a lot 'clearer' then that... Looks kinda 'milky' to me.....
Mitch
Old Jun 1, 2007 | 04:46 PM
jamzwayne's Avatar
Geez.
Flush the radiator.
Old Jun 1, 2007 | 05:27 PM
quackrstackr's Avatar
-RP-
Delphi was part of GM but got spun off to be it's own entity. It was also the first of the large parts suppliers to file bankruptcy.
They make automotive components for a whole lot of manufacturers though.
