Computer Problem (A Challenge of F150online.com)
Old Dec 8, 2006 | 07:26 PM
31Charlie's Avatar
The Problem: When your computer starts up only the backround image comes up.
The Tools: You have Task Manager, Command Prompt, and IE 6 (that is ready to crash at any moment). There is only one user acount of this dcomputer. Nothing else is available unless it can be brought up using the CMD.
The Diagonstic: The computer is looking in the wrong/non-existant folder for the windows desktop.
The Challenge: A non-believer mockingly told me to ask F150online.com for help since they "always seem to be able to solve everything" (note sarcasm).
31C
Old Dec 8, 2006 | 07:31 PM
BalogUK's Avatar
since you have the command prompt:
also assuming WinXP
try system restore to an earlier date-
type at prompt:
you could do this in normal mode or safe-mode (reboot, before windows loads push F8)
%systemroot%\system32\restore\rstrui.exe
Old Dec 8, 2006 | 07:35 PM
31Charlie's Avatar
also assuming WinXP
type at prompt:
I forgot to explain the input devices are unresponisive during start up since they are bluetooth and require windows to be running.
Old Dec 8, 2006 | 07:38 PM
BalogUK's Avatar
so your keyboard isn't working either??? (is that what you're saying?)
Old Dec 8, 2006 | 07:40 PM
vader716's Avatar
Steelers fan or not...
Try reboot, before the XP flag comes up, hit F8, select safe mode than run the system restore.
If that doesn't work come back for more.
Oh and smack the non-believer in the back of the head.
Old Dec 8, 2006 | 07:44 PM
31Charlie's Avatar
Keyboard works, just not during start up...
31C
Old Dec 8, 2006 | 07:49 PM
Tical84's Avatar
You could use the command prompt to open MSCONFIG, in which you can select "safe boot" and do a restore.
BalogUK's Avatar
okay- access the cmd prompt- type in msconfig the system utility should appear, find the boot.ini tab- click the box for /SAFEBOOT from there, reboot- computer should start in safemode instead... from there, go back to CMD, type in the restore prompt as posted above...
if it fixes everything when you are done, go back to msconfig > boot.ini > de-select /SAFEBOOT
Old Dec 8, 2006 | 07:52 PM
Tical84's Avatar
Ya, that's more detailed but what I said, except you can't do it from the default location. You have to go to C:\Windows\pchealth\helpctr\binaries (assuming XP)
Old Dec 8, 2006 | 07:58 PM
31Charlie's Avatar
Safe mode did not work.
I think the easiest way to do it would be if I could tell windows where to find the desktop at because right now it is looking in the wrong location.
31C
Old Dec 8, 2006 | 08:01 PM
Tical84's Avatar
Not sure how to do that but did you try the restore command from the command prompt, you didn't mention that?
Old Dec 8, 2006 | 08:13 PM
31Charlie's Avatar
Yes. The program/window would open and imediately freeze.
Old Dec 8, 2006 | 08:19 PM
vader716's Avatar
I doubt that it is the fact that it can't find the desktop, its sounds like a service or startup file is failing or hanging
Did safemode fail to start or did the restore failt to work?
Old Dec 8, 2006 | 08:25 PM
31Charlie's Avatar
The restore failed.
I get an error message when I try and access my desktop that says desktop could not be found in:
C:\Documents and Setting\LocalServices\
it should be looking in:
C:\Documents and Settings\31Charlie\
Does anyone know how I can access the control panel?
31C
Old Dec 8, 2006 | 08:40 PM
vader716's Avatar
you can launch the individual components rather than going into the CP directly.
Perhaps try to boot into safe mode, create a new user, log in as that new user and work from there. Perhaps your profile is just hosed.
