computer gurus please help!
Old Oct 6, 2006 | 06:12 PM
Fordwitflows's Avatar
I am trying to display a background on my screen and nothing happens. When I select "set as background" nothing happens. When I go into control panel and display all I can change is the color. The rest of the box is all grayed out.
BTW, I have windows XP
Anyone know how to fix it???
Old Oct 6, 2006 | 06:13 PM
Rockpick's Avatar
Moderator &
So you have a photo or something that you want to utilize as a background on your machine?
I think that it has to be in a certain format before you can do it... .jpg or .bmp I know work.
Old Oct 6, 2006 | 08:05 PM
wxscpo's Avatar
Try this
Right click on the desktop anywhere
Select Properties
Select the desktop tab
Browse to the picture you want as your background and select it. This should put your picture in the list of desktop backgrounds and it should be the selected item. You should be able to hit apply and your background is set.
Hope that helps you.
Old Oct 6, 2006 | 08:15 PM
02SuperCrew4X's Avatar
Also, you may have "Active Desktop" enabled. Right click anywhere on your desktop and choose "Refresh." Sometimes the computers at work get all screwed up like that and need a quick refreshing.
Old Oct 6, 2006 | 08:23 PM
I see all the "factory backgrounds" plus the one I choose, but the box is grayed out an not letting me click on it to select and choose.
Old Oct 6, 2006 | 08:25 PM
Originally Posted by wxscpo
Try this
Select Properties
That is the box that is all grayed out
Old Oct 6, 2006 | 08:27 PM
akheloce's Avatar
HAHA, just spent an hour figuring this out on my buddy's laptop...literally just got done like 2 minutes ago. You need to go to:
Start-Run-
Regedit.exe and navigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\System
(and)
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\System
Delete the values "Wallpaper" and if there, "Wallpaper Style" in the right side pane.
The entries may not be in both "current user" or "Local Machine" so check them both.
It's caused by deleting spyware that took the value in the registry over.
BTW, you may want to back up your registry first, just in case.
Old Oct 7, 2006 | 01:10 AM
kobiashi's Avatar
If I knew how to fix XP I'd be richer than Bill Gates.
(Cue laugh track)
The only known way to fix the Microsoft OS is to trash it and buy a Mac.
