adobe illustrator cs help???
Old Aug 21, 2006 | 12:02 AM
KiCk aSs FX4's Avatar
I have adobe illustrator cs not cs2 and I made this thing by just using the lines. now I cant figure out how to fill in the gaps with color. I tried the bucket tool but it wont work. i need help!
Old Aug 21, 2006 | 03:59 AM
TeckBargins's Avatar
not sure exactly what your asking for, but if you made mulitple layers, you can only edit the layers that you have selected.
You can merge layers then select the new (merged) layer and make changes.
Let me know if thats not what you meant?
Old Aug 21, 2006 | 11:52 AM
02SuperCrew4X's Avatar
OK, I had to switch over to the Mac to try this out. Anyway, I drew something in Illustrator CS using the line tool (not even sure what I drew) and I tried to use the "paint bucket" to fill it in, after selecting all the lines and grouping them together as one. Lemme show you the error I got:
Thats when I noticed that the bucket is not a normal paint bucket like in MS Paint. It's a Symbol Styler Tool. That means you can only use it to style symbols, which is why I got that error. I am working on a way to fill in the shape I made, and if I figure something out, I'll let you know. Funny, I did graphic design for so many years, and with this new version of Adobe's products (CS and CS2) I can't figure out a LOT of stuff. Wish me luck...
Old Aug 21, 2006 | 12:06 PM
you are going to have to make a selection, use the selection tool... then should be fine.
Old Aug 21, 2006 | 12:43 PM
kobiashi's Avatar
Good luck.
(PS - Mac. Nice.)
Old Aug 21, 2006 | 12:52 PM
I've got a Mac and a PC set up on a KVM switch. I prefer the Mac for most everything, but there are some games and things I like to do that you cant get for the Mac. Hence the reason for both...
Old Aug 21, 2006 | 01:01 PM
kobiashi's Avatar
Well, you don't need that KVM switch any longer. Now that the Mac is on Intel, you can run both OSes on one machine. (Either by rebooting in Windows thru boot-camp, or switching between OSes on the fly without rebooting thru Parallels. (Which I am told runs just as fast as native - although I've yet to actually see it)).
So RUN (don't walk) to your nearest Apple store and get the new MacPro, and while you're at it get either the 23" or 30" inch Apple monitor (with their new low prices, how can you say "no"?)
Old Aug 21, 2006 | 01:25 PM
you are using the wrong paint bucket tool but that is what I am trying to do. If you hold down the eyedropper there is another paint bucket which is the one where you can use the swatches an not the symbols if you know what I mean. And then I click in between the design I made with the lines and it doesnt work, nothing happens.
I think it has something to do with the backround being "empty" and you cant fill the empty space because there is nothing there. If I make a square all I have to do is select it and then click on a color and if fills it in but since I made a bunch of lines there is no surface area to fill in. So how do I make this "surface area".
btw it is all on one layer if that helps
Old Aug 21, 2006 | 03:02 PM
here ya go, let me know if this helps: Press K to get Live bucket tool
You can see the tools selected on left hand side of screenshots, sorry forgot to use alt-prnt screen
Line Tool Used:
Selection Tool Used
Fill Bucket Used Press BUTTON "K"
Old Aug 21, 2006 | 03:35 PM
I dont have cs2 so I dont have the live paint or live bucket tool. I tried it anyway and it didnt work. Thanks a lot for trying though. I guess Ill have to somehow get the upgrade
