Reverse camera installed!!! (pictures)
Originally Posted by ThumperMX113
Can someone post a link to the camera?
Here ya go Thump. http://cgi.ebay.com/USA-New-120-deg-...QQcmdZViewItem
Just make sure you get this one (2.8mm 120 Degree)
He ahs anpther one that only 90 degree, so you wont get the range of view I have on mine.
BREW
BREW
BREW
Or, you can get both the Camera and the cord for cheaper at his website, Kawamall
EDIT: BREW empty out your PM mailbox, it keeps telling me that yours is full when I try to send you one.
Would that be the right one to order? http://www.kawamall.com/pd_car.cfm
Does anyone know with my Eclipse AVN 5435, would it turn on soon as I put it into reverse?
Thanks a bunch guys, you guys just saved me a chit load of cash!
That'd be the one that BREW has and that I just ordered. There should be a wire coming out of your headunit that you need to hook up to a wire that becomes hot when the truck is put in reverse.
Done
THUMP....I have a wire dedicated to my camera coming out of the head unit. Im sure the Eclipse will have the same. Then I just plugged the video cable from the camera into the back of the head unit. Again, an input dedicated to the camera.
Good luck!!
BREW
HAHAHA..sorry man, I had to. But hey, at least I gave you some good info to look at. See, I'm always trying to help out around here.
https://www.f150online.com/forums/sh...d.php?t=241829
See, there I go, helping again.
BREW
BREW
I can't say anything....
First time out with that prop after I'd waited a year to get a new one.....
Have no idea what I hit or when I hit. It's just the one blade, the others have small scratches in the paint in about the same spot but didn't touch the metal. I never heard or felt anything. I wasnt happy with it anyway.
And Matt, fix your trailer lights.
The trailer is getting redone/customized after I repair the gel coat on the boat, hopefully get to the trailer in two weeks, unless the boat tears up again.
Which means your trailer is never going to get redone, cause you run the **** outta that boat. 26 Gal of gas in 20 mins
Originally Posted by Ruanolik
Did you wire the camera to constant power, or tap onto the reverse wire?
I just installed the same alpine unit myself last week. Great head unit ( tr-7 bypass installed too)
I taped into the reverse wire. I have another thread here about it. I had some sort of voltage drop from the break lights, so everytime I hit the breaks the screen on the head unit would reset it self. I wound up installing a relay and it solved all my problems. Give me a minute and Ill get you the link to the other thread.
BREW
Originally Posted by MikeF150
Tom... any pics of that sleeping cat you backed over?
(Long time.. no talk... hope all is going well... Mike)
Yeh no doubt man....haven't talked to you in a while. Whats new?
Trust me, I wish I hd pictures of some cats I ran over. Them bastards are just to fast...LOL. I gotta do something, they're after the KOI in my pond.
BREW
Sheesh...I haven't had mine out in a week
