Furthering Science !!!
Old May 27, 2006 | 03:01 AM
sleddogg's Avatar
Originally Posted by wild-mtn-rose
Hmmm, how do I antistatic my fan blades, think if I rub them with a dryer sheet they'll become static free??
I don't consider myself a fool either but my money sure parts in a big hurry!
The dryer sheet may work, but it really has to do more with the amount of static in the home itself. Once you stop using your heating system you should see less build up as the relative humitity increases in you home.
I have found one thing that does work to help slow the build up. Eagle One detail spray on the fan blades, but this really only works for blades with a smooth finish.
I part with a fair share also Rosie. Its called a spouse.
Sled...
Old May 27, 2006 | 03:08 AM
wild-mtn-rose's Avatar
Originally Posted by sleddogg
. . .I part with a fair share also Rosie. Its called a spouse.
Sled...
Wait, I'm a spouse too, are you saying that we girls spend too much money??
Old May 27, 2006 | 03:23 AM
sleddogg's Avatar
Well that all depends on what you are spending it on.
This may need to be scientifically answered by Kobi. Maybe he has a proven theory.
Sled...
Old May 27, 2006 | 03:34 AM
I see...hmmm...I definitely think we need Kobi's assistance with this perplexing problem!!
Old May 28, 2006 | 02:21 PM
Originally Posted by kobiashi
Unless of course I was referring to both. For example I could be in the lab, applying heat to a kettle which contains water, and slowly increasing the temperature of the heat with the intention of eventually melting the kettle. As the heat increases, the water boils then eventually the kettle itself boils and melts, or melts and boils (I guess it depends the melting point, in terms of temperature, that the material the kettle is made of is). In which case, the water AND the kettle would both boil . . . so I guess that makes your statement that the "kettle never boils" incorrect.
Never assume.
The water would boil and evaporate before the kettle would boil, so noone will see both water and kettle boil together, therefore no lab testing is necessary.
Old May 28, 2006 | 02:47 PM
JS2003's Avatar
I doubt the dryer sheets would work, because I think the friction created by the fan blades moving through the air would be enough to cause a big enough static charge to attract dust.
Besides, you ignore an even more inviolate scientific law: that which is most difficult to clean (or hard to reach) will get the dirtiest!
Old May 29, 2006 | 02:53 AM
Damn, I'm screwed My ceiling fans are about 12' off the ground. I have to drag a heavy 10' step ladder in to climb up and clean them! One good thing, with them so far up, it's not so noticeable when they're hairy!!
Old May 29, 2006 | 11:09 AM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
You obviously dont have one of these Little Giants!
Click on image to view, I so want one soooo bad!
Old May 30, 2006 | 02:46 AM
Nope I don't. It wouldn't be tall enough anyhow:
Stepladder Height: 4' - 7'
The ceiling fans are too far away from a wall to use an extension type ladder, it has to be a step ladder and that one only gets 7' high, wouldn't quite reach.
Old May 30, 2006 | 11:25 AM
UrbanCowboy's Avatar
Got to be careful with those things. I was messing with the Little Giant here at work and the damn thing slid down and crushed my toe. I was taking it down from a full ladder extension.
Old Jul 26, 2006 | 07:13 PM
lees99f150's Avatar
You Can Lead a Horse to Water, But a Pencil Must Be Lead
Old Jul 26, 2006 | 07:26 PM
BRUZRs_Daddy's Avatar
Have you ever heard that "A watched kettle never boils"? (By the way, it is an anagram which gives you: "Set to brew? Leave kitchen, lad!")
Anyway, a watched kettle never boils?
Wrong.
I've just proven that it does.
Just doing my share to further science. Now that my work here is done, I figure it's just a small step to coming up with a unified field theory.
You must have some connections up in Humboldt County... 'Cause you be smokin' some dank buds, my brotha...
Old Jul 26, 2006 | 09:39 PM
36fan's Avatar
Apparently we need to do some scientific research regarding the fans.
I propose:
leave one fan blade alone (control)
clean one blade with water
clean one blade with regular furniture polish
clean one blade with a dryer sheet
and clean one blade with sleddogg's Eagle One detail spray
all blades would obviously be marked to identify what was used to clean it
let the fan run for 6 months continuous. Atthe end of 6 months the dust buildup would be evaulated, and the results noted.
I hypothosize the dirty will remain the dirtest, followed by therest being relatively close in dirtiness.
Now all I have to do is find some government entity to give me a $500,000 grant to complete the scientific evaluation
Old Jul 26, 2006 | 09:41 PM
36fan's Avatar
Wrong.
Your next you assignment is to evaluate whether molasses reall catches more flies than vinegar...
Old Jul 27, 2006 | 12:14 AM
silversvt04's Avatar
rewritten to mean.......the pencil lead the horse to water, but you can't make either drink.
