Large Attachments
Old Apr 11, 2006 | 05:00 PM
UrbanCowboy's Avatar
Large Attachments
We're having a hell of a time getting large attachments out over email here. I'm talking like 5-7MB zip files. Can't even get em out of Outlook without Mapi spooler issues. Should this be expected with attachments this size? That's what I've been telling them so far.
Old Apr 11, 2006 | 05:15 PM
vader716's Avatar
absolutely....
Do you run your own mail server? I block email over 10 megs but anything over 2-3 megs is unreliable at best...
If you are running through a remote web server the connection is either timing out or the remote server is blocking the mail due to size.
What about putting it on your website and then emailing a link to the file.
Old Apr 11, 2006 | 05:21 PM
Originally Posted by vader716
absolutely....
It's all done over SMTP connections with a remote vendor. Website is not a feasible solution. I just wanted to make sure I wen't full of my typical BS. There is a 10MB limit from the provider.
Old Apr 11, 2006 | 05:25 PM
vader716's Avatar
well if you are using a pop connection try going into outlook under services or accounts (depends on version) go to the advanced section of your pop connection and drag the server timeout as far to the right as you can. It will at least help to cut down on your client dropping the connection. Nothing you can do about the server side though
Old Apr 11, 2006 | 05:26 PM
Already tried it.
Old Apr 11, 2006 | 05:31 PM
vader716's Avatar
Originally Posted by UrbanCowboy
Already tried it.
Figured as much....
Well....
You're Screwed....
See the rest of us use this new protocol...FTP....really cutting edge stuff...
